Mechanics
HIGH PITCHED WHINE FROM ENGINE
2002 Dodge Dakota
Engine problem
2002 Dodge Dakota V6 Four Wheel Drive Manual 60000 miles
My 02 Dakota 4x4 is making a high pitched whine from what sounds like the engine compartment or under the cab. It happens at speeds from 40 to 70 mph and is intermittent. If I take my foot off the gas is goes away slowly, if I put in the clutch it goes away quickly. On cold starts I can hear a slight squeak coming from the pulley system and when I checked I saw some coolant coming from the metal heating tube that is on the top/side of the water pump. Could it be the water pump bearing starting to fail or is this something more serious?
I've had it in 3 shops and no one can figure out what is wrong. Any info would be appreciated.
PistonPhil
December 3, 2007.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
