Replacing speed sensor
WPBDAKOTA
  • DODGE DAKOTA
Anyone know where the speed sensor is on a 2000 dakota? And how hard it is to replace. And if it can cause the brake/abs/tranny light to come on and make the speedometer stop working?
Sunday, January 22nd, 2006 AT 9:32 PM
2CARPRO JACK
  • 11,533 POSTS
It is in the top of the rear diff
Tuesday, January 24th, 2006 AT 4:10 PM
MOODYTODAY
:) I had the same problem on my 99 dakota. It is located on the top of the rear diff. Look for a connector there and two bolts holding it in place. It took me less than a half an hour to change it out.
Monday, January 30th, 2006 AT 2:34 AM
LOKI
Ty i'm having the same problem.
Tuesday, April 18th, 2006 AT 4:46 AM
STEVEN KENNEDY
  • 5 POSTS
There one on the back of the transmission by the speedometer cable
Monday, April 8th, 2019 AT 9:56 PM
CARADIODOC
  • 33,738 POSTS
You folks are talking about two different sensors. The vehicle speed sensor is on the left side of the transmission as STEVEN KENNEDY mentioned. The sensor on the top of the rear differential housing is strictly for rear-wheel-anti-lock, (RWAL) brakes, and nothing else. If the truck has four-wheel anti-lock brakes, it will not have that sensor. Unlike the cheaper version on GMs that use a three-channel system, Chrysler has always used a four-channel system that modulates the two rear wheels independently of each other. That uses a wheel speed sensor at every wheel.
You should be starting new questions specific to your vehicle for a couple of reasons. First, the first person didn't even bother to list the engine size, transmission type, two or four-wheel-drive, or the mileage. Those are all factors in answering the question of how hard it is to replace the sensor. We're lucky they told the model year because prior to 1989 models, they did have a speedometer cable screwed into the vehicle speed sensor. A failed sensor would only cause the cruise control to be inoperative, and the transmission's lock-up clutch to not engage. Other than that, there would be no symptoms and the speedometer would work just fine. We also look at the mileage to make generalizations as to the best suspects or best places to start looking for a diagnosis.
The second problem is this was a private conversation between two people. Others are welcome to read the responses when researching their problem, but when you piggyback a reply, it is only going to be seen by the two individuals involved originally. We get automated e-mails directing us back here when a new reply shows up. None of the other experts will see the addition or have a chance to reply. That does a huge disservice to the person making the addition and may not get them the help they need.
Posting a new question also adds to the list of similar problems so we can see what is common.
If anyone needs it, here's the link to post another question:
Tuesday, April 9th, 2019 AT 12:09 AM
JOHNWHEELER
  • 2005 DODGE DAKOTA
Electrical problem
2005 Dodge Dakota V8 Two Wheel Drive Automatic 50.000 miles
'05 Dodge Dakota SLT quad cab 2wd-My speedometer reads 28mph, my odometer doesn’t change but my tachometer shows engine speed. The ABS & brake warning lights came on at the same time. What’s wrong?
Monday, July 29th, 2019 AT 12:21 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Check ABS system for codes and repair and that should clear up the speedometer issue
most common the rear axle speed sensor
RIVERROADRIDER6
  • 2001 DODGE DAKOTA
  • V8
  • 75,000 MILES
My speedometer quit working. I was told by a friend that the sensor at the transmission was probably bad. Part was purchasde and installed but did not help. What else could be the problem?
KELVIN SCHAUER
The one that actually controls the speedometer is in the rear end housing not in the transmission. There also may be some tsb's (technical service bulletins)available thru your local dealer on this issue. And probably will have a trouble code set in your computer(check engine light on)that will have to be cleared.
