No Spark
BROKENEGGS
  • 1987 DODGE DAKOTA
  • 3.9L
  • 6 CYL
  • 20,000 MILES
Why Is Their No Fire Going To My Coil? Everyone Keeps Telling Me That My 1987 Dodge Dakota L E 6 Cyl 3.9 Has An Computer, I Sure Wish Someone Would Let Me Know Where To Locate It At, Since I Can't Seem To Be Able To Find It.
Monday, March 24th, 2014 AT 3:38 PM
OBXAUTOMEDIC
  • 3,711 POSTS
I take you mean that you do not have 12v at your Coil. The most probable cause is the SCC(The Spark Control Computer).
OPERATION > SPARK CONTROL
Spark Control allows the computer to determine the exact instant that ignition is required. It then signals ignition coil to Produce electrical impulses which fire the spark plugs. The computer eliminates the need for either vacuum advance units or centrifugal advance weights. Spark control operates in one of the following modes:
OPERATION > SPARK CONTROL COMPUTER
The Spark Control Computer (SCC) is mounted on the left inner fender panel (Pickup models) and center of the firewall (Van models). The SCC consists of a printed circuit board which simultaneously receives signals from all data sensors and analyzes these signals to determine spark advance and, on models with feedback carburetor, the air/fuel mixture. Incorporated within the computer are the electronics for throttle control, EGR and air switching systems. After determining spark advance, the computer operates the engine feedback system (on models so equipped)
Electronic Spark Advance Computer (ESA) is located On right forward fender panel.
Tuesday, March 25th, 2014 AT 6:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, I cannot seem to find a pic of the exact location this is all I can find, it is is located On right forward fender panel. Pics attached ir what you are looking for.
Tuesday, March 25th, 2014 AT 5:58 PM
BROKENEGGS
  • 198 POSTS
The Only Thing I See On My Right Forward Fender Is Three Fuses Which Are All Good.
Wednesday, March 26th, 2014 AT 6:36 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Take a look in same area except look on Drivers Side. If still don't see it could you take a few pics of engine compartment and post them. I still cannot find a pic of a exact location of it.
Wednesday, March 26th, 2014 AT 11:13 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Also could you post your VIN number
Wednesday, March 26th, 2014 AT 11:14 AM
BROKENEGGS
  • 198 POSTS
Obxautomedic: Yes Sir I Found The One On The Left Fender And It Looks Like The First One In Your Two Photos. This One Is Connected To The Part That Goes To The Carburetor Air Filter. But I Can Not Find Anything On The Right Fender That Would Even Resemble Either One Of Your Photos As To What This Computer Would Look Like. Does This One Operate Everything?
Wednesday, March 26th, 2014 AT 4:30 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Yes it does. And there is only one.
Ok, to make sure, the engine is the 3.9L cause the location of the esa for the 3.9 is supposed to be in the same area except on the Passenger Side. It being on the Drives Side indicates the it's a 2.2L
Thursday, March 27th, 2014 AT 5:59 AM
BROKENEGGS
  • 198 POSTS
You May Have Misunderstood Me Are I Stated The Wrong Thing. The Computer I Found Was On The Passengers Side, I Was Unable To Find One On The Drivers Side. This Vehicle Is An 1987 Dodge Dakota L E 6Cyl 3.9L Vehicle Identification Number 1BFN14MOHS515367 I Hope This Helps. Also I Don't Have Anyway Of Knowing What Each Fuse Is For Since It Does Not Show Any Info By Each Plug in. It Tell You To Refer To The Owners Manuel Which I Don't Have. Where Can I Get A Owners Manuel For This Truck Or Just A Diagram Of Fuse Panel Showing What Each Plug in Is For?
Thursday, March 27th, 2014 AT 8:56 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok.
Here is the Fuse Block Layout.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 1 - 20 Amp (Yellow)
Hazard Flasher & Turn Signals Panel Indicator, Side Marker Lights.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 2 - 20 Amp (Yellow)
Back-Up Lights, A/C Fan & Clutch Relay Coil.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 3 - (Blank)
Not Used.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 4 - 30 Amp (Green)
A/C Or Heater Blower Motor.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 5 - 20 Amp (Yellow)
Taillights, Park, Side Marker, License & Panel Lights.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 6 - 20 Amp (Yellow)
Stoplight, Dome & Ignition Switch Light, Time Delay Relay, Courtesy Light.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 7 - 20 Amp (Yellow)
Horn & Relay, Cigarette Lighter, Radio & Clock Memory, Key-In & Headlight Buzzer.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 8 - (Blank)
Not Used.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 9 - 10 Amp (Red)
Radio & Clock Power.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 10 - 20 Amp (Yellow)
Turn Signal & Front Side Marker Lights.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 11 - 20 Amp (Yellow)
Windshield Wiper & Washers.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 12 - 3 Amp (Violet)
Cluster, A/C & Heater Control, Cigarette Lighter Light, Ash Tray & Radio Lights.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 13 - 5 Amp (Tan)
Fuel Gauge, BRAKE Warning, Oil Gauge, Seat Belt Warning- Buzzer, Temp. Gauge, Volt Gauge, Speed Control, Oil & Temperature Lights, Fuel Pacer System.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 14 - (Blank)
Not Used.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 15 - (Blank)
Not Used.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 16 - (Blank)
Not Used.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 17 - Relay
Hazard Flasher Warning.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 18 - Relay
Relay.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 19 - Circuit Breaker
No other description.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 20 - Relay
Turn Signal Flasher.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 21 - Buzzer
Warning.
IDENTIFICATION > FUSE & CIRCUIT BREAKER IDENTIFICATION > 22 - Relay
Horn.
Friday, March 28th, 2014 AT 1:43 PM
OBXAUTOMEDIC
  • 3,711 POSTS
As for the Computer there is only one and it is on the Passenger Side.
Friday, March 28th, 2014 AT 1:52 PM
BROKENEGGS
  • 198 POSTS
This Is The One I Found. I See There Is A Round Hole In The Side Of It That Has A Raised Edge That A Line From The Carb Hooks Too. Where This Hooks To The Computer Is Torn And Has A Hole In It. How Will This Effect My Being Able To Start This Truck? What I Am Really Trying To Figure Out Is Why It Is Not Firing. One Thing It May Be Is That It Seems Like There Is No Current From Ignition Key Switch To The Coil, And I Know The Coil Has No Fire Since I Took The Coil Eire Loose From The Distributor And Check For Spark While Someone Else Turned The Motor Over And There Was No Spark. Can You Help Me Figure Out What Is Wrong So I Can Get This Old Truck Back Running?
Friday, March 28th, 2014 AT 3:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, do this test if you can. You will need a multimeter. I circled and pointed to the correct Computer Section and Cavity. I cannot find diagram or anything that tells me which is the #1 cavity on the Distributor. Not sure if may be Market inside or outside of the Harness.
NO START (NS) TESTS > NS6F - (3.9L DAKOTA ONLY) CHECKING DISTRIBUTOR PICKUP POWER CIRCUIT
Ensure distributor connector is disconnected. Turn ignition key off. Disconnect 10-way connector from computer. Connect ohmmeter between cavity No. 3 of 10-way connector and cavity No. 1 of the distributor engine harness connector.
If ohmmeter shows continuity, replace the computer.
NOTE: Before replacing the computer, check the terminals of both cavity No. 3 of the 10-way connector, and cavity No. 1 of the distributor engine harness connector to make sure they are making a good connection.
If ohmmeter does not show continuity, repair wire between cavity No. 3 of the 10-way connector and cavity No. 1 of the distributor engine harness connector.
Friday, March 28th, 2014 AT 6:24 PM
BROKENEGGS
  • 198 POSTS
Can The Spark Control Computer Keep Current From Flowing From Ignition Key Switch To The Coil?
Saturday, March 29th, 2014 AT 7:25 AM
BROKENEGGS
  • 198 POSTS
Your Diagram Of Spark Control Computer Does Not Look Like Mine. Mine Only Has Two Plug ins One On The Left End And One On The Right End When Looking Directly Into The Front Of The Computer, Each Has A Lot Of Wires All Different Colors Running Out Of Them.
Saturday, March 29th, 2014 AT 3:25 PM
BROKENEGGS
  • 198 POSTS
Your Diagram Of Fuse Box And Their Arrangement Are Completely Different From Mine. Mine Has More Fuses In A Row Than Yours Does
Saturday, March 29th, 2014 AT 3:31 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok
Can The Spark Control Computer Keep Current From Flowing From Ignition Key Switch To The Coil? From what I can see in the schematic yes. The Negative Side goes directly into the Computer in the 10 Plug Connector in Cavity #1. The Positive Side also goes into the Computer via a few other areas the into Cavity #2.
The Diagram is a schematic and you would just locate the Orange Wire and I believe cavity No. 1 of the distributor engine harness connector is the Orange with Yellow Stripe.
As few the Fuse Block - I check on the 88 model and show same.
Also double check your VIN you are a digit short vin numbers are 17 digits you only listed 16.
I found a better pic of the 10 pin connector
Saturday, March 29th, 2014 AT 5:22 PM
BROKENEGGS
  • 198 POSTS
After Recheck It Now Seems That Fuse Panel Is The Same As Your Pic. Except For One Thing Your Pick Shows Something Other Than An Fuse By The # 19 Plugged Into # 3 Plug in My Panel Does Not Have This Item Since All Plugs Have Fuses Only. And Since You Showed A Different Pic Of The 10 Pin Connector, It Now Seems The Same, But Mine Also Has a Smaller Pin Connector. After You Have Let Me Know That This Computer Does Control The Power Flow From The Ignition Key Switch To The Coil I am Starting To Think The Computer Is causing My Problem. What Do You Think? I Was Also Told That The Voltage Regulator Controls The Flow Of Power To The Coil. Is This True? If So Where Is It Located On This Truck?
Sunday, March 30th, 2014 AT 7:25 AM
OBXAUTOMEDIC
  • 3,711 POSTS
No, the Voltage Regulator Regulates/Controls the Output Voltage from the Alternator. That's it. If the voltage is not regulated it can burn up your Battery plus other electronics in your vehicle if voltage it to high, if not enough voltage then won't charge battery enough to maintain.
If you can do the Test I posted earlier you would know if it is the Computer.
Sunday, March 30th, 2014 AT 8:18 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Forgot to say that the Voltage Regulator is Integrated in the Alternator
Sunday, March 30th, 2014 AT 8:20 AM
BROKENEGGS
  • 198 POSTS
No Wonder I Could Not Find It Thanks For That!
Sunday, March 30th, 2014 AT 9:01 AM
