2CarPros - Car Questions & Answers
1967 Dodge Coronet Repair Question
Topics covered: Battery, Terminal, Positive cable.
Asked on September 11, 2010
1967 Dodge Coronet Phantom Voltage
1967 Dodge Coronet V8 Two Wheel Drive Automatic 4,304 miles
Hi. Here's A Perplexing Problem That Baffles
Me To No End. I Remove Both Battery Terminal
Cables, Positive And Negative, Then Set Meter To
20 Volts D.C.---- Then Touch Negative Cable Which
Is Still Grounded To Motor, Then Touch Negative
Post On Battery....And I Get A 3.67 Volt Reading
On The Meter!! Where Is The Voltage Coming From? Is The Battery Bleeding Current? I Get
The Same Reading With The Positive Cable Connected To Positive Battery Terminal Too.
What's Up With That? Thanks!!
Avatar Asked by 1967dodge
Answer
Replied on September 13, 2010
The Problem Was Fixed Today By Me 1967dodge,
No Reply Posts Are Needed, Thanks!
Tiny Response from 1967dodge
1 question asked
