2CarPros - Car Questions & Answers
Dodge Charger Repair Question
Topics covered: Driveshaft, Vacuum leak, Wheel.
Asked on May 23, 2007
Dodge ramcharger
I got a 1990 dodge ramcharger 4x4 with a 318 w/ 184,000 miles. The front axel does not engage into 4 wheel drive. The gears are fine I cleaned the shift motor and I believe the splines are to, I believe there is a vacuum leak thats on top of the t-case and if there is how would i fix? Also not sure what kind of t-case is in it but it has the longer 4x4 stick engager in it, can you tell me what the measurements on a rear driveshaft would be, and if I get a lift on the truck do I need to exstend the driveshaft?
Avatar Asked by rykennedy
No Answer Yet
