alternator wiring diagram?
1998 DODGE CARAVAN
310,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
TERRY BOYD
  • 5 POSTS
I need to know precisely where to find the fusible link between the alternator and the battery, since both lines to the alternator connections run in one wrapped bundle.
Suspect that fusible link may be the problem as to why not only the alternator light is on, but I had weird glitches in instrument panel (loss of tachometer and speedometer, ABS light coming on). In process of changing the PCM which I suspect may have received damage to the voltage regulator chip inside. Really getting tired of dismantling the top of my engine compartment if you know my meaning. And i need my one and only transportation!
Added Information:
New alternator and new battery installed prior to symptoms described.
Feb 20, 2017 at 11:13 AM
STEVE W.
  • CAR REPAIR CONTRIBUTOR
  • 15,157 POSTS
The link is in the positive cable right near the battery terminal. Check the ASD relay as well. Here is the wiring diagrams for the alternator so you can see how the system works with a guide to test the wiring as well.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Feb 20, 2017 at 12:03 PM
TERRY BOYD
  • 5 POSTS
Will check. Thanks
Feb 20, 2017 at 12:41 PM
TERRY BOYD
  • 5 POSTS
Steve W. That is not it! This is not letting me add a photo as it should. so I cannot show you. Main big cable from post is to the starter/starter solenoid, smaller red cable (ten gauge) goes to the PDC, also to the PDC is a dark green cable (ten gauge) and that is to the PCM. No fusible links. I am not a pro mechanic, but I do know what a fusible link is and where they should be placed and placing this one at the target area (battery) is not the proper place. Logically a fusible link is placed close to the source of the powering device in order to protect the system and targeted area which in this case is the battery and PCM since the voltage regulator circuitry and control chip are located within the PCM.
Thanks for the help, but not for this computer controlled system without an external voltage regulator unlike a 1970's model of Dodge.
Feb 21, 2017 at 6:07 AM
TERRY BOYD
  • 5 POSTS
For all With this problem.
Check with your local auto parts store and have them look up your vehicle to see whether your car has a fusible link in the charging system. I did just that since my local Dodge dealer would not tell me if it did or not. This particular model of Grand Caravan does not have a fusible link in the charging system. The reason given were the amount of relay, fuses and other safeguards installed in the system. The voltage regulating system is a control chip in the voltage regulator circuitry that's inside the PCM and cannot be repaired independently, the entire PCM must be replaced.
Feb 21, 2017 at 9:20 AM
STEVE W.
  • 15,157 POSTS
I guess that Dodge must lie then.
These are the wiring diagrams for that vehicle and both show that it has a fusible link (A111 Dark.green ten gauge) spliced to the black with gray wire that goes to the alternator at the battery end.
And in your complaint about being given wrong information you state "Main big cable from post is to the starter/starter solenoid, smaller red cable (ten gauge) goes to the PDC, also to the PDC is a dark green cable (ten gauge) and that's to the PCM. NO FUSIBLE LINKS"
The dark green wire is the fusible link. It is bonded (electrical splice 09) to the Black with gray stripe about one foot down the harness.
Go look at the wire on the battery terminal of your alternator. What color is it?
Feb 21, 2017 at 10:17 AM
  • 54,334 POSTS
I agree with Steve W. the fusible links are near the battery on the fender well of the drivers side tire and they fail often I have replaced many myself.
Ken - Site Admin
Feb 21, 2017 at 6:51 PM
TERRY BOYD
  • 5 POSTS
Maybe these will help what I said. And as I said there's no fusible link in this vehicle. Left RED is main, right RED leads to PDC and that Dark Green (same color as my schematic says the fusible link A111 is) leads from PDC to the PCM. The bundle under the PDC between the PDC and PCM has the Red Main in it but NO FUSIBLE LINK. So, after tracing every bundle from battery to alternator including the leads to the ignition system and fuel injectors and not finding anything I went to the Dodge Dealer parts store to get a brand new ASD RELAY and asked their chief mechanic (showing every photo I had taken). He looked it up and looked up my VIN and found that this 1998 Grand Caravan Sport does not have a fusible link. So, when I post what I am told by a dealer's mechanic after an hour and twenty minutes of searching and waiting it's not my imagination. Besides it makes no difference now anyway because I had to order a whole new PCM after having this one checked out because the voltage circuitry chip smoked out. Presumption is by what the codes showed is that it lost ground apparently of which I have no doubt since that fender was severely damaged in an accident 2 yrs ago. Just one of several parts that had to be replaced in time as a result. Like I saud, Thanks For Your Help!
Feb 21, 2017 at 7:25 PM
CARADIODOC
  • 34,309 POSTS
There's a lot of misinformation here. You found the dull dark green wire. That is the fuse link wire. Tug on it. If it acts like a wire, it's good. If it acts like a rubber band, it's burned open. The problem is it doesn't come off the battery cable like in years past. The smaller positive battery wire bolts to the under-hood fuse box. That connection is where the fuse link wire is bolted.
The next problem is most of these diagrams only show what is relevant to the specific circuit. You could have multiple fuse link wires bolted to that connection, but the one for the alternator does not go to the Engine Computer. It goes straight to the alternator's output terminal.
There is no need to even have to know where that fuse is unless testing proves otherwise. Just measure the voltage on the alternator's output stud. It should have full battery voltage all the time. If it does, you're done in that circuit.
Forget the ASD relay. It's true that it sends current to the alternator's field winding, but it also powers the ignition coil pack and injectors. If the engine runs, the ASD relay is turning on. Less than ten seconds to eliminate those two circuits.
It is also correct the voltage regulator lives inside the Engine Computer, but it is incapable of being damaged by the alternator. They put it there to simplify the circuitry needed to provide information used to modify the target charging voltage. That can include wide-open-throttle, turning on the AC compressor, engine running too hot, ambient air / battery temperature real cold, etc. It is possible for the regulator circuit to fail, but it's not very common. I've only run into one since 1990. That low-current circuit is also real easy to test. Look at the two smaller terminals bolted to the back of the alternator. The engine must be running for them to have voltage from the ASD relay. One will have full battery voltage. The other one must have less, but not 0 volts. If you find 0 volts, the brushes are worn. (Nine bucks for a replacement assembly). If you find exactly the same voltage on both terminals, there is a break after that point. That could be the voltage regulator is open, but it is much more likely there's a corroded terminal in the connector going to it.
Typically you'll find between 4-11 volts on the second terminal. The lower the voltage, the greater the difference there is across the two of them, and the larger the electromagnetic field is. That one voltage will tell you if the low-current input circuit, including the voltage regulator, is working.
Feb 21, 2017 at 8:09 PM
STEVE W.
  • 15,157 POSTS
Looking it up by VIN wouldn't matter. The wiring doesn't change for the charging system based on the option package for the Caravan.
The accident it was in however could easily have changed that. Whoever repaired it probably decided that a straight run of 10 gauge green fuse link was easier than splicing together the wiring like the OEM part. Not uncommon. Did the PDC also get replaced at that time?
Either way, you seem to have it repaired. Good luck with it. Oh does it have the clunk in the front that they get after about 80K when the sway bar bushings wear out?
Feb 21, 2017 at 8:32 PM
GIUGGIOLA
I had this problem and had to replace the ECM cost me $140.00 for a rebuilt unit I got from eBay, all fixed, I love this site.
Feb 22, 2017 at 12:11 PM
CKAHRL
Steve: I have a 2000 Town and Country. I am sure the fusible link to the alternator is shot (I have reasons). Apparently, the link is right by the battery/powerthingy. But before I take the cable bundle apart, it is unclear to me what kind of link it is. Some places say 14GA others say 16GA. I saw one place where it said 10GA, which sounds way too big. Also, in the schematic you give, the fusible link says: 10GA Drk GRN. But the wire running to it says NCA. What in the world is NCA? Is the link really 10GA? Autozone has links listed as 14GA and one as 16GA with a fuse which sounds small. Does the 10GA refer to the cable, in which the 14 GA would be right?
Dec 10, 2019 at 2:16 PM
CARADIODOC
  • 34,309 POSTS
If you "have reasons", please share them so we can have the same confidence in your diagnosis as you do. Also, please start a new question specific to your vehicle, and be sure to include the engine size and mileage. Some diagrams are different for different engine sizes, and we look at the mileage when making some judgement calls. When you add to an old question, it was a private conversation between just a few people, and they are the only ones who will get an automated e-mail link when an addition is posted. As such, none of the other experts will see your addition or have a chance to reply. That limits the help you will receive. Your new question might also help others researching this topic.
We can try to solve your problem here, but if you need to start a new question, here's a shortcut to get you there quicker:
There were four sizes of alternators available for this model and year. The wiring harness will always be the same except for the fuse or fusible link. Those are selected at the factory for the size of the alternator being installed. In this case, all they show is a 10-gauge wire, denoted by its dark green insulation. In this diagram, the fuse link is shown way up in the top right corner with my green arrow pointing to it. The small circle on top indicates that end is bolted to the under-hood fuse box. "ES09" right below it indicates that is a soldered splice to the wire it protects. That is circuit "A11 6 BK/GR". "A" circuits are always tied right to the battery positive side. This is circuit A11. It's a 6-gauge wire with black insulation and a gray tracer, (stripe). Most commonly these fuse links are part of a larger bundle of wires, but they are left out where they can be seen.
The place to start is by measuring the voltage at the alternator's large output terminal with the engine not running. That's the red arrow in the diagram. You must find that voltage is the same as battery voltage at all times. If you find 0 volts, suspect the fuse link is burned open. It's best to check this with a test light rather than a digital voltmeter. The advantage to using a fuse link wire is they are slow-acting, so they tolerate momentary current surges. The disadvantage is when they burn open, they leave a carbon track behind, and those can conduct enough current for a digital voltmeter to pick it up and falsely show there's 12 volts at the output terminal. A test light needs current flow to operate, and sufficient current can't get through that carbon track to make the bulb light up. For that reason, test lights are more accurate in this type of circuit.
If you need a new fuse link, they can be purchased at any auto parts store. You'll get a piece about a 8" long. That is plenty to be cut to make two or three repairs. The length of the fuse link isn't important. All that matters is this is the weak link in the chain, so it will burn open before the rest of the wire overheats.
Dec 10, 2019 at 3:30 PM
KEITH HAMM
the alt. shows 90 amp with a load the battery voltage still falls to about 12.2 volts sense wire has 8.6 volts ing. wire has full battery volts the b+ volts at computer is full battery volts running out of ideas
Sep 21, 2020 at 7:15 PM (Merged)
CARADIODOC
  • 34,309 POSTS
Is that all one sentence? Do you mean you get 90 amps during a load test or there is a sticker on it that says it's a 90 amp alternator? What are the three voltages on the three alternator wires? The two smaller ones must be measured with the engine running.
caradiodoc
CAT206
  • 13 POSTS
In removing the alternator the location of the ground wire was melted off of the back, tracing the wire back a little showed the melted other side. Need to replace the alternator and have to replace the ground wire, it is wrapped with the power wire and I need to know where it goes.
DOCFIXIT
  • 18,828 POSTS
There is no ground wire can you ID color ? Think it is Black/Gray if so power feed from BATT cable through a fuesible link. That maybe what fried. was ALT light on before?
CAT206
  • 13 POSTS
I am attaching a photo of what is left of the wire, I can go try to pull on it to see what color the wire sheathing is, but i didnt notice a color before.
DOCFIXIT
  • 18,828 POSTS
Yep that is power lead
CAT206
  • 13 POSTS
ok so how does one go about changing it? is there a diagram? there is no room to work in this vehicle so it is very hard to trace the wires back
DOCFIXIT
  • 18,828 POSTS
remove ALT see if ypou can cut insulation away. will need to soilder a 10AMP fuselink. may end up having to replace charging loom. have ALT tested to see if that is reason for wire frying
CAT206
  • 13 POSTS
ok alt was bad, as i said it had melted the metal around the connector. So alt is out and we are going to replace the entire wire, however I am in need of a diagram as to where this wire goes. It feeds into a larger bundle of wires and we lose the wire in the mess, so if we can get a diagram as to where it goes we can just bypass the wiring bundle and wire it directly to where it goes. and Docfixit - Thank you for all of your help, you have been absolutely wonderful!
DODGEPODGE
  • 111 POSTS
It seem there is something wrong with a black inline box by the alternator. I need a wiring diagram where those wires run back to. For awhile when the voltage dropped I tapped on that black box and it would start charging again. But now that does not work. So either something happened in there or there is an open wire. Thanks
CAT206
  • 13 POSTS
was finally able to uncover enough of the wire past the burnt part to see that it was a black and grey wire, traced it around and found out it links to a green wire at the main fuse box, where the pos battery cable connects. Still planning on replacing the entire wire now just searching for a place to buy one. Again thank you for all of your help.
Good afternoon,
I attached a wiring diagram for you to view of the charging system.
Can you post a picture of what you are hitting?
DOCFIXIT
  • 18,828 POSTS
Part of wire needs to be 25AMP fuselink wire
DODGEPODGE
  • 111 POSTS
Roy not sure of what you mean by hitting?
CAT206
  • 13 POSTS
we pulled a used wire (full wire with both ends) off an identical vehicle in a local junkyard, we ran it in with other wires and connected it correctly, the van is up and running. thank you for all of your help.
I am sorry. You said tapping.
DOCFIXIT
  • 18,828 POSTS
Good job
DODGEPODGE
  • 111 POSTS
On the little black box in the large 12 volt line right by the alternator. Do you know what i'm referring to Roy?
WRENCHTECH
  • 20,761 POSTS
[quote]Part of wire needs to be 25AMP fuselink wire[/quote]
For a 100A alternator?
DODGEPODGE
  • 111 POSTS
Do you really need a picture Roy?
There is so much under the hood I would like to see what you see.
JIMOLSON
1997 Caravan 3.3 285000 kms. Regular service including major service at regular intervals. Current problem is electrical system failure. The battery has been replaced and some faulty wiring connections were repaired on the fuse box. Now with the battery fully charged using a charger (12.7 V) the engine starts fine and with the engine running the voltage is at 11.8. Turn on the electrical appliances and the voltage drops to 11.4. Leave the battery without a charger overnight and the battery voltage doesn't drop. Failed alternator?
The Alty needs replacement-Good reading is between 13.5v - 14.5v engine running.
Battery @ 12.7 open voltage-when alty goes in play should increase .05-2volts that will take you to the max of 14.7- if the alty is reconditioning the battery.
HTH-Good Luck
DODGEPODGE
  • 111 POSTS
See the black thing in the middle of the picture with the red wire coming out. That is hat i'm talking about.
That is the main junction block for power.
I would remove the cover, remove the negative battery cable and clean the terminals real well and make sure they are secured tight.
DODGEPODGE
  • 111 POSTS
But do you know what is in there? i also checked to see if there is voltage to that point and there is not. so i need to know what is in there. there are no clips to open it up. it is twenty five years old and if i crack it open. i wont be able to replace it.
The top is a cap.
There is a power wire from the battery and the other wire goes to the alternator.
The top should come up.
They are secured by nuts.
DODGEPODGE
  • 111 POSTS
Although it is a junction box it does not open up Roy. there is no cap, there are no nuts as you describe. i'm talking about one thing you're talking about another.
