Where is the fuel filter?
MIKET45
  • 2006 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 50,000 MILES
Where is the fuel filter on my 2006 dodge caravan?
Do you
have the same problem?
Tuesday, August 26th, 2008 AT 6:45 AM
BMRFIXIT
  • 19,053 POSTS
The fuel filter is attached to the inlet of the fuel pump this guide will give you an idea of how to change it out with diagrams below to show on your car
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
and
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Tuesday, August 26th, 2008 AT 9:51 AM
TJANES
  • 2007 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 47,000 MILES
When at a stop sign as I give the van acceleration there is a couple seconds delay or hesitation and then the van will go. 2? First does this sound like a good place to start by replacing the fuel filter and 2 I have been told that this filter on this van is hard to change. Thanks tim
Thursday, December 17th, 2020 AT 8:40 AM (Merged)
  • 108,005 POSTS
That is a good place to start, but they are a pain because they are on the top of the fuel tank. THe tank needs lowered to access it. As far as your concern, I would check fuel pump pressure first. If it is within spec, then the filter isn't the problem.
Here is a how to for checking fuel pump pressure. You will need a pressure gauge, but most parts stores will lend them to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
CURTIS BAUM
  • 3.3L
  • V6
  • 213,000 MILES
I think I may have a clogged fuel filter. After I get gas my car will stall most times and have to be restarted but is fine after that.
Your fuel filter is in the tank as part of the pump. Plus this is normally not a plugged filter. This is normally raw fuel in the vapor canister. You actually have two canisters but the way these work is that when you fill the tank and under normal operation there is vapor put off by the tank. That vapor is captured rather than put off into the atmosphere for emissions reasons and better fuel mileage.
When the PCM calls for it, the purge valve opens and allows this vapor stored in the canister into the engine. If there is raw fuel in there then too much vapor comes in and it stalls the engine or makes it run rough. This normally happens most after fueling because when it is filling up that is when then most amount of vapor is put off into the system then when you start the vehicle and the purge is opened it dumps all this fuel and vapor into the intake.
I would suggest removing the canister and seeing if there is raw fuel in them. If there is, replace them and the purge solenoid because once these have fuel in them the charcoal breaks down and causes the purge to stick.
Let me know what you find and we can go from there. Thanks
SCGRANTURISMO
  • 4,897 POSTS
The fuel filter for your vehicle is part of the fuel pump module which is located in the fuel tank. I have included factory instructions for the removal and installation of the fuel pump module for your vehicle in the diagrams down below. Please go through this guide and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
ARTIE PAR
How to replace fuel filter 2006 dodge caravan
  • 108,005 POSTS
You're not going to like this. It is only replaceable as part of the fuel pump module (in the tank)
ANNILEI GONZALES
  • 169,838 MILES
Fuel leaking from sending unit.
SCGRANTURISMO
  • 4,897 POSTS
This sounds like your vehicle's fuel pump module's o-ring gasket has failed. There is a rubber o-ring gasket that goes where the fuel pump locking ring is that seals the fuel tank where the fuel pump module goes. In the diagrams down below I have included the factory guide for the removal and installation of the fuel pump module which will incorporate how to replace the o-ring gasket. Please go through it and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
ANNILEI GONZALES
Okay, I posted pictures changed hose connection thought it was that still no change. Can anyone tell me anything else?
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Please double check the o-ring and make sure that it is seated properly. Also ensure that the snap ring is tightened all the way down. You usually have to tap it in place with a rubber mallet and a plastic wedge. Try not to use anything metal, or if you have to use anything metal to tap it in place, do it very carefully and avoid any sparks, obviously because you are working around fuel. If it is still leaking, then the fuel pump module itself must have a crack in it allowing the fuel to get through. Also double check the fuel line connections at the the fuel pump module. Make sure that they are tight and that there are no cuts in the lines themselves. Please get back to us with what you are able to find out.
CHARLOTTERUSHING
  • 2004 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 44,000 MILES
Where is the fuel filter located
Thursday, December 17th, 2020 AT 8:41 AM (Merged)
BLACKOP555
  • 10,371 POSTS
It is located inline from the fuel tank and the engine, folow the fuel lines from the gas tank and you should see it, plain as day.
ATXT63
  • 6 POSTS
  • 6 CYL
  • 92,000 MILES
Can you tell me where the Fuel filter on a 2004 Dodge Grand Caravan is located? Thank you.
BMRFIXIT
  • 19,053 POSTS
You have to drop down the fuel tank
ATXT63
  • 6 POSTS
I have dropped the tank but did not see any lines that matched the replacement filter. Is it inside the tank?
BMRFIXIT
  • 19,053 POSTS
The fuel filter is replaceable only as a part of the fuel pump module
if what you have has long fuel lines it is for an older model year
ATXT63
  • 6 POSTS
It has 3 lines for "IN, OUT, and RT". The same fuel filter is shown for the 2003 and 2004 model. Is this the correct filter? Thank you.
BMRFIXIT
  • 19,053 POSTS
If you don't have nothing on top the fuel tank then its the wrong one
you dont need to replace the filter and you dont have one
its part of the fuel pump
Thursday, December 17th, 2020 AT 8:42 AM (Merged)
