2006 Dodge Caravan ABS Brakes?
2006 DODGE CARAVAN
37,000 MILES • 6 CYL • FWD • AUTOMATIC
JAYSGRL
How can you find out if my van has ABS brakes? It doesn't say it on the brake pedal. The owners manual says "if equipped". I do have rear drums if that makes a difference.
Jan 31, 2008 at 11:54 AM
LEGITIMATE007
  • CAR REPAIR CONTRIBUTOR
  • 5,121 POSTS
look under your hood on the right hand side and against the firewall there is a big black round thing called a power booster. on it there is a big hard hose coming off of it. and comming out of the middle is a big metal thing called a master cylinder. now does this thing have several different wires coming off of it with two caps where you can put fluid in it. that is abs. it looks quite complicated. as a non abs unit does not. also it should say abs on the unit.
Jan 31, 2008 at 2:07 PM
