dead battery?
2007 DODGE CARAVAN
76 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
POPPY1954
Yesterday morning went to leave and vehicle was completely dead not lights or anything, went out 3 hours later to pull battery, decided to check first and it started right up and have had no problem since, is there a possibility that the battery could have an intermittent short or is it something else maybe?
Nov 19, 2015 at 5:51 PM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
Follow the smaller positive battery wire to the under-hood fuse box and be sure that connection is clean and tight. Follow the smaller negative battery wire to the body and be sure that one is tight and not rusty. These guides can help us test the battery and then replace it if necessary.
and
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Nov 19, 2015 at 6:52 PM
POPPY1954
Thanks, I'll check it out.
Nov 19, 2015 at 7:34 PM
SINGINGMOMMY4
My husband forgot to turn the headlights off after using the van yesterday around 3pm and the van was not used again until this morning around 5am. When I turned the key the headlights and radio and internal lights were working but the car made a clicking noise and would not crank. I turned everything thing off and then waited a few minutes and tried again and it cranked up slowly. I left it running for about 20 minutes or so and then drove it about 2 hours before returning home. Once I got home I waited about 10 minutes and then I tried to crank it again and it cranked with no problems like normal. Is there need for me to worry about this? Could it just have been a low battery? Should I still get it checked out because of further problems?
Sep 22, 2020 at 11:16 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
I would still have the battery checked
most likely the light was the cause to drain it
most caravans have a battery safe relay where if you left the light on or other acc should turn them all off to save the battery from draining
MOSCO2005
  • 6 POSTS
The reason it was clicking is because their was to much strain on the battery with everything turned on ( Not enough power ). Nothing to worry about for next time as long as your alternator is working your battery should be good and charged.
BRANDON666
Van starts sometimes and runs fine sometime it dies and sometimes it just clicks by fuse box whats wrong?
HMAC300
  • 48,601 POSTS
check battery for condition including load test. chec starter relay for corrosion on prongs. then have scanned for codes your tpim module may be screwing up
AR
Electrical problem
2004 Dodge Caravan 6 cyl Automatic 85000 miles
Went to start car and it did not turn over, made ticking noise and all the needles on gauges on dash went completely over to right then back to off posistion. Got boost start with no problems and drove it for 4 days without any futher problems. No warning lights appeared and unsure if internal light had been left on causing battery to run low.Today went out driving in the morning, went to go out again 2 hrs later and the same problem. No lights left on. No problems boost staring again and after running for 15 min continues to start fine. Has original battery. Is this caused by old battery or some other reason.
  • 31,937 POSTS
Hi there ,
Get the battery load tested, check all the terminals are clean & tight, and have the starter motor checked as the solenoid may be faulty.
mark (mhpautos)
HALO1FAN
My battery is not completely dead but doesn't have enough power to start engine. After jumped and car ran for about 20 minutes and when shut off didn't have enough battery power to start engine again. Had dealer check new battery of 1 month who reported battery still good. Break lights sometimes stick and dealer stated even if you don't see the break lights on but pedal on a bit it would still drain battery. What else could that be besides dead battery and do you really think by the break pedal sticking a bit but not enough to see actual break lights on, could drain the battery to make it dead enough to not have enough power to start car?? Thanks!
Dunno about the brake switch idea-why don't you just disconnect the brake switch -charge up the battery again and see what happens. If it works then its the brake switch-if not the problem is coming from somewhere else. Could be the alternator not putting out or the battery is not taking it-
JDL
  • 16,098 POSTS
I'd check for battery drain, track it down. Make sure the charging system is working ok. As far as the brake pedal, never heard of that, I guess anything is possible.
DCASIAS
its cold and the starter just clicks
Sep 22, 2020 at 11:18 AM (Merged)
Are you using the correct grade of oil/vicosity? If so could be the starter, starter relay,transmission position switch and ignition switch assuming the battery condition and connections are good.
FEMEL
I can be driving along, and the engine cut off. No jerks, nothing, I only know because acceleration doesn't work. After I coast to a stop, it takes about 2 min to start it back up. During this time, the engine does not turn over, nothing happens when I turn the key. Nothing. Then after about 2 minutes it just starts and goes on as if nothing was wrong, and may not happen for another month. It only happens in cold weather, I though -10C but today it happened at 1C first thing in the morning. A little scary on a highway on a curve, amazed I am still alive! I am in a 2001 Dodge Caravan 3.3L V6 engine not Grand Basic SE with many miles. Has done it since 2003 but it is now my darling daughter who is affected and so now it matters. Chrysler has not been able to replicate or fix the problem. It doesn't happen often, but when it does it is mighty scary.
  • 110,190 POSTS
It sounds like you loose all power. Do the lights or anything work when this happens? Have you checked for power at the source, the battery? Make sure terminals are clean and tight and not corroded.
FEMEL
I can put the emergency flashers on while I am waiting for it to start back up, so electrical is good, it is just the engine that will not start
  • 110,190 POSTS
Have you been able to check to see if there is spark and fuel to the engine when this happens?
FEMEL
no, I am usually on a highway, my only thoughts are to get the hell out of the way and stay alive! To be perfectly acurate, I wouldn't know how to do this in any case.
  • 110,190 POSTS
I understand. Here are how to directions for testing both. All you will need is a fuel pressure gauge. Most parts stores will lend them to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Let me know if you have questions.
FEMEL
This should be done when it happens? Or can I do it anytime? This is a random event which nobody can duplicate and may not happen again for a day, or a week or if I am very lucky a couple of weeks. Depends on how cold it gets. Never happens during the summer.
  • 110,190 POSTS
It needs to be done when the problem occurs. That is when you will be able to identify if it is an electrical issue or fuel related.
REEFUS54
Our car was running fine this am, drove it about 25 miles, parked. Went to leave, battery was dead. We jumped the battery off, and it cranked, but the dash lights blink, and the battery is not charging at all. We drove the 25 miles home, turned off car, wouldn't crank again.
DOCFIXIT
  • 18,828 POSTS
Recomend replace battery probable cell short or sulfated.
CARADIODOC
  • 34,309 POSTS
Also, measure the voltage across the battery terminals. It should read around 12.6 volts with the engine not running, and must be between 13.75 and 14.75 volts when the engine is running. If less than 12 volts with the engine off, there's a shorted cell in the battery. If the voltage stays the same after the engine is started, the charging system is not working. There are some easy fixes, but you will need to troubleshoot the system first.
caradiodoc
