Mechanics
CRANK SENSOR LOCATION
2003 Dodge Caravan
Electrical problem
2003 Dodge Caravan 6 cyl Front Wheel Drive Automatic 103000 miles
WHERE IS THE CRANKSENSOR LOCATED ON A 3.3 CARAVAN? GOT CRANK SENSOR CODE, WHEN VAN STALLS THE ASD RELAY AND THE FUEL PUMP RELAY CYCLE ON AND OFF, IT DOES THIS WHEN IT SEEMS TO WARM UP. STARTS WHEN COLD. DIDNT SEE SENSOR ON THE TRANNY, WAS TOLD IT WAS ONTOPOF TRANS INLINE WITH THE FLEXPLATE. DIDNT SEE IT. SHOULD I BE LOOKING FOR ANOTHER PROBLEM ALSO? SEE ALOT OF THREADS ON THIS PROBLEM BUT DIDNT SEE ANY FIX FOR IT.
Highwayman9011
February 1, 2008.
Right side of engine under exhaust manifold
let me know
http://www.2carpros.com/forum/automotive_pictures/99387_caravan_33_1.jpg
BMRFIXIT
Feb 2, 2008.
[quote=" BMRFIXIT" ]Right side of engine under exhaust manifold
let me know
Thank you very much, Its my girlfriends car and its making me nuts. Are the symptoms common? Any other ideas? I will change sensor on Monday, I have to weld a broken trailing arm on her windstar, great girl but crumby luck!
Thanks again, will post when done
Anthony
AD
Highwayman9011
Feb 3, 2008.
AD
