Mechanics
POWER WINDOW
2002 Dodge Caravan
Electrical problem
2002 Dodge Caravan 6 cyl Front Wheel Drive Automatic 77,000 miles
Drivers side power window won't go up. The motor is working but the window is down and won't go up. I can hear what sounds like a cable or something when I push the power window button but the windown is not engaging. I can lift the window up but when I release it, it drops down into the door. The passenger side window is fine.
The repair guy wants to replace the motor even though it is working. Is it possible it is just off the track or that the cable is loose or something?
Any suggestions to avoid a $400.00 repair bill.
Thanks
AD
Sanstokes
August 7, 2009.
Need window regulator 90% of the times comes completed with the motor installed in it
BMRFIXIT
Aug 8, 2009.
AD
