no spark
2002 DODGE CARAVAN
117 MILES • 6 CYL • FWD • AUTOMATIC
EASTZHANG
Hi, experts. I have a 2002 Dodge Caravan 3.3L. After I had put it in storage for a month, I couldn't start it but crank. Now I pulled it to a garage and got checked. First, no spark; then checked ignition coil was good, camshaft sensor was good, crankshaft sensor was good. So in the next step, we aimed to the PCM. OBDII code was P0601, but check engine light wasn't on. I have read a lot of threads about P0601. It looks like in most of the cases, drivers even don't notice the existance of the P0601. Is my car's problem related to this code? Is the problem related to the PCM? Is there any other possibilities other than PCM failure? I badly need help. I have heard I can plug in another same model's PCM to get it checked, is it true? Any suggestions? Thank you ahead.
From Kevin
Aug 16, 2011 at 4:17 AM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
The P601 is an inability to control memory so I don't think that will cause a no start. It still sound like a crankshaft angle sensor or the ASD relay is not working.
Here is a guide that will get you going in the right direction.
Check the ASD by using this guide
Also, check for voltage on the wire feeding the coil pack, (dark green / orange, I think), any injector, or either small wire on the back of the alternator. You should see 12 volts there for just one second when a helper turns on the ignition switch. That voltage should come back during cranking. If you never see voltage there, swap the automatic shutdown (ASD) relay with a different one and try again. If you have voltage for that first second, the relay is okay. If it doesn't reappear during cranking, the crankshaft position sensor and camshaft position sensor circuits must be diagnosed.
The crankshaft position sensor must be installed with a spacer to set the critical air gap. It requires either a thick paper spacer from the dealer or some aftermarket sensors have a thin plastic rib molded to the end.
Here is the relay and fuse locations (Below)
Aug 16, 2011 at 5:04 AM
EASTZHANG
Yes, I saw the 12V just after the helper turns on and came back during cranking.And I had also checked other leads. Other leads I guess should work like this, during cranking the resistance between one lead and ground should alternate between open and zero, and this didn't happen, it stayed open. So I had concluded that there were no pulse signals went to the ignition coil. Any idea? I ordered a new ASD relay just in case
Aug 16, 2011 at 9:28 PM
CARADIODOC
  • 34,309 POSTS
You can't measure resistance in a powered-up circuit. If you found voltage on the feed wire to the injectors and coil pack, the Engine Computer turned on the automatic shutdown (ASD) relay. That means it got pulses from the crankshaft position sensor and the camshaft position sensor. Those are the pulses that tell it when to fire an injector and coil.
Originally you said there was no spark. Do you have it now? How did you check the coil pack?
Aug 17, 2011 at 8:12 PM
EASTZHANG
Thank you for reply.
I checked the coil like this:
1. I measured resistances between pins in the feeding plug,they were around 1.2ohms. The six big poles counld be divided in three groups, and the resistance between them were around 15k ohms.
2. I used another known good coil to connect to the feed plug, and plugged in one spark cable with a spark plug, there were no sparks appear.(The body of the spark plug touched ground)
For the feeding plug of the coil, I guess it works like this:
one prone provides +12V, the other three connect or disconnect to ground which is controlled by PCM. This connecting and disconnecting make pulses. If I put the plug into the coil, for sure I can't measure the resistance when the power is up; but if I leave the plug unconnected, there will be no power give to the three prone, so I think I can monitor the connecting and disconnecting by measure the resistance between one of the three prongs and ground. Am I right?
Aug 18, 2011 at 12:53 AM
CARADIODOC
  • 34,309 POSTS
I never checked the resistances of the coil. It's unlikely all three would fail at once. If one fails, you'll just have two cylinders not firing.
The best way to approach this is to use a scanner that displays live sensor data, then watch the cam and crank sensor signals to see if they're listed as "no" or "present". I think you're going to find one of them missing.
Aug 18, 2011 at 1:07 AM
EASTZHANG
Yep I installed the new ASD and it fired right up. Thanks for the tip you guys are great!
Aug 18, 2011 at 2:28 AM
CARADIODOC
  • 34,309 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
Aug 18, 2011 at 4:59 AM
TOMEL
Electrical problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic 120000 miles
I was driving and started to feel hesitation in the engine, at the same time the engine light started flashing. I drove another 2 minutes looking for a place to stop and the engine died, and I could not start it again. Now engine turns over but van won't start. I checked and found that I had no spark. I had the followings codes:
1388 (Auto shutdown relay),
1389 (No Z1 or Z2 voltage seen by the computer when the auto shutdown relay is used),
353 (Coil #3 is not reaching peak current at the right time)
300 (Misfire detected in multiple cylinders.)
442 (A leak has been detected in the evaporative system)
455 (A large leak has been detected in the evaporative system)
456 (A small leak has been detected in the evaporative system)
I noticed a corroded ground braid on the left side of the engine (it fell apart when I touched it) so I used some jumper cables to ground the engine block thinking it's a grounding issue, but still no spark.
Any ideas where to start or what to change?
Thanks in advance,
Tom
Mar 15, 2017 at 1:00 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Mark ASD relay and switch it with a similar relay
check fuses
suspect and check crank sensor
TOMEL
Thanks for the quick reply,
I checked the ASD relay and it's fine (replaced it with the wiper one to check). The ASD fuse however was blown. I replaced the fuse and am now able to start the van. It's still running rough like as if not on cylinders are firing (just like it did before it died).I disconnected the battery to clear the codes. I didn't run it long enough to have new codes come in, should I? I suspect that the ASD fuse will just blow again given enough time. The only code I have now is:
1684 (The battery has been disconnected within the last 50 starts.)
Since it is running (rough but running) could it still be the crank sensor? or is a faulty coil pack more likely since I did get a p0353 error?
BMRFIXIT
  • 19,053 POSTS
Check starting and but bad than I would look for a coil problem
if crank sensor bad it will not start at all or it will start and than stall and die
check fuel pressure
TOMEL
I checked the coil and found that coil 3 (cyl 3&6) was open, So I replaced the coil pack with a new and tested one (Tested using a multimeter, all coils read about 12k ohms). I started the van up again and still found that it was running rough, after about 30 sec the check engine light came on. I turned off the van and checked the codes again, and found that the
353 code is back (Coil #3 is not reaching peak current at the right time)
Not sure where to go from here.
Many thanks for all your help!
Tom
BMRFIXIT
  • 19,053 POSTS
1.Possible causes for DTC to set are: defective ignition coil No. 3, defective PCM, or defective connectors or wiring.
2.Turn ignition off. Disconnect ignition coil connector. Turn ignition on. Using scan tool, actuate Auto Shutdown (ASD) relay. Using a test light connected to ground, probe Brown/White wire at ignition coil harness connector. If test light illuminates brightly, go to next step. If test light does not illuminate brightly, repair open or high resistance in Brown/White wire between ASD relay and ignition coil. ASD relay is located in Integrated Power Module (IPM). IPM is located on left side of engine compartment, next to battery.
3.Using a test light connected to positive battery voltage, probe Dark Blue/Orange wire at ignition coil harness connector while cranking engine for 5 seconds. If test light does not blink/flicker, go to next step. If test light blinks/flickers, replace ignition coil.
4.Turn ignition off. Ensure ignition coil is disconnected. Disconnect PCM connectors. PCM is located on left side of engine compartment, near front of battery. Measure resistance of Dark Blue/Orange wire between ignition coil harness connector and terminal No. 2 at PCM C1 harness connector. If resistance is less than 5 ohms, go to next step. If resistance is 5 ohms or more, repair open in Dark Blue/Orange wire.
5.Measure resistance between ground and Dark Blue/Orange wire at ignition coil harness connector. If resistance is 100 k/ohms or more, go to next step. If resistance is less than 100 k/ohms, repair short to ground in Dark Blue/Orange wire between ignition coil and PCM.
6.At this time, PCM is assumed to be defective. Replace PCM. Program the new PCM. See PROGRAMMING .
7.At this time, conditions for DTC to set do not exist or fault is an intermittent problem. Start engine and allow it to idle. Ensure engine is at normal operating temperature. Using scan tool, monitor parameters related to DTC while wiggling connectors and wiring harness. If value changes while wiggling connectors and wiring harness, repair connectors and wiring harness where wiggling caused value to change. If value does not change, review Freeze Frame data using scan tool. Attempt to duplicate condition that caused DTC to set. Check for any related technical service bulletins that may apply. Visually inspect related connectors and wiring harness. Repair connectors and wiring harness as necessary
RICHARD ALFORD
Electrical problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic 82000 miles
every thing seems to be working but have no spark but have power to the coil what should i do?
No sparky
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
BUDGUY
  • 5 POSTS
Engine Mechanical problem
2002 Dodge Caravan 6 cyl Front Wheel Drive Automatic 160000 miles
battery good charge, plugs and wires good, no power on the wires going to coil with a test light. Someone took my van for a joyride and ditched it on the drivers side, under the drivers side wheel-well there's a computer that looks damaged, will this computer stop my van from having spark or is there another problem lying somewhere? Van ran great until it was ditched. Please help.
  • 110,190 POSTS
Are you saying the computer is between the tire and the inner fender?
BUDGUY
  • 5 POSTS
Spoke with the dodge dealer and they said it's the tcm and should not be why there's no power to the coil. That as long as the Id is the same I can change it out. It's between the fender and inner fender on the front drivers side, but why won't my reader work and why is there no spark or even power to the coil
BUDGUY
  • 5 POSTS
did the key bump on off on off on and get P1388 ASD Auto shutdown relay circuit. Is my relay bad? or does it show this code and something else may be to blame. Had a visual inspection of wiring and all looks ok. Can anyone start me in the right direction in regards to the asd? Please. Thanks!
  • 110,190 POSTS
That is why you have no spark. Have you checked the relay?
BUDGUY
  • 5 POSTS
Where is it on an 02? My manual shows where it is on earlier models but has no info about mine, even the electrical diagrams are for older models. I have searched the net and still not exactly sure which is the auto shutdown relay. I have checked the fuse center and swapped some around because they are the same and no luck
  • 110,190 POSTS
It is in the integrated power module located on the left side of the engine compartment. Here is a picture:
https://images.2carpros.com/forum/automotive_pictures/249084_5_81.jpg
Let me know if this helps. Joe
DESIGNPLUS
2002 Dodge Caravan 6 cyl Front Wheel Drive Automatic 138000 miles
I cant get fire from coil on a dodge grand caravan 2002 i have change coil,cam sensor, and crank sensor,check all relays and fuses are ok
thank you if you can help
david
If you have power to the coil wire brown and white I recommend you check the coil driver circuit within the computer. No power to the coil check and test the ASD Relay and for an open wire
BUDGUY
  • 5 POSTS
If ipm and pdc are the same yes I have changed out the ones marked relays with ones that work. Still get the code 1388 on the odometer doing the key bump and no power coming to my coil. I haven't tried hooking up my scanner again because I forgot to bring it with me. Will try unhooking the "appears to be damaged" tcm like previously mentioned and see if I still get the error "not odb compatible".
Should I trace the dk grn/org wire from the power dist center to the asd and even to the coil like my manual shows? Would be odd a light accident would break this wire though.
A friend said crankshaft sensor but no code for this and from reading the manual it says the pdc will shut off power to the coil, the fuel injectors and fuel pump. I can rule this out because my fuel pump turns on when the key is on? This code should also be shown when I do the key bump test correct? or how many codes will it show? all of them?
You guys are great. Donation coming your way when I get paid! Thanks for the help. Hopefully I get this solved soon :(
NJTEMPE
Computer problem
2002 Dodge Caravan 6 cyl Two Wheel Drive Automatic 150000 miles
My Caravan 3.3 L is not getting spark. i removed the ignition coil and ECU unit, however, parts store was unable to test either component. Wanted to know if there is a way for me to test these components at home, and if so, how are they tested?
Thank you
BMRFIXIT
  • 19,053 POSTS
replace crank sensor
check ASD relay
check fuses
DENMCD
Electrical problem
2001 Dodge Caravan 6 cyl Front Wheel Drive Automatic 169000 miles
The other day while driving down the highway, it just quit! no warning no hesitation, it was just like someone switched off the ignition. I have a code scanner, but no codes are stored on the computer. which is actually kind of strange, because there has been an error code relating to emmisions for about a year, and it isn't coming up either. I have repaced the coil, and was going to try replacing the crankshaft sensor, but am now wondering if it is the computer. Is this something i can just buy and install, or is there programming required?
Check for power at coil- No power test the auto shut down relay-
DENMCD
Ok, I checked the coil, and there is power to it. Any other ideas? should/can i replace the computer?
Thanks
Test both the cam and crank sensors before you think computer-might be if both checks out
DENMCD
Hey rasmataz!
thanks for the quick reponses! i have now replaced the cam and crank sensors. still no luck! i also have inquired at both the major auto parts stores in the city, and neither of them have any listing for the PCM module. does this mean it is dealer only? looks like i am going to have to bite the bullet and take it to a garage!
Thanks
POPEYE519
Hi, was driving down the road van quit running . Coil is new wires plugs all new. Got a crank sensor went to install it noticed wire at the plug were bare . Repaired the damage. Van starts runs fine . Leave my garage go for a drive it is fine . Come home shut if off then restart and misfiring . No codes at all no spark on cylinder four only . Stumped. assuming a wire problem again . This collection is less then a week old .
Thanks
Mar 16, 2018 at 11:54 AM (Merged)
  • 54,350 POSTS
Follow this test to see if the coil is getting a trigger signal.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
DECKER07
I have no spark on my van. I do have some codes
P0123,P0118,P1193, and P1598. I was driving down the road and just died. Please help...
Jan 13, 2019 at 12:00 PM (Merged)
JDL
  • 16,098 POSTS
Hello, I can tell you what codes mean, but, if your saying there is no spark at the plugs, with the vehicle cranking. I'd check the no spark problem first.
I'd check the primary circuits at the coil pack. Go from there.
