Mechanics
GRAN CARAVAM ES
2001 Dodge Caravan
104,000 miles/3.3L V6Automatic, 2 wheel drive
No noise, but pretty large pools of water from drain tubes under front/back of van when you park it.
The AC went out and I took it to a reputable mechanic first week of June (5 June 07 to be exact)
Ended up replacing:
Actuators/Seals/HousingDFOORS45Evaporator Core
Receiver drier/expansion valve
A/C system was completely charged (included Recover, evacuate, and recharge system) front unit
This all cost right at $1900 including labor. Worked fine for 3 weeks, now, driver side blows hot air, passenger and back blow cold. Any suggestions? Could temp control for driver side be bad? Please help, I am broke now. Thanks a million!
Grizzly56
July 1, 2007.
Sounds like it. There should be an actuator motor on the d/s temp blend door. Be sure it is moving when temp is changed
Jack42
Jul 2, 2007.
AD
