Mechanics
TRANNY CODE
2000 Dodge Caravan
2000 Dodge Caravan 93k mi. All of a sudden, Transmission will not shift past second gear. Code PO755
shift solenoid " B" malfunction. Question; should I try to reset using the on off method to reset, or have the solenoid switch replaced, speed sensor, and the valve body cleaned? Any help is appreciated.
Jay Templeton
January 8, 2007.
Hey jay,
Definitely would recommend an accurate diagnosis as it couls also be a harness/wiring issue. Unless the speed sensor is faulty. No worries and if the fluid is not " burnt" then a filter change will suffice! ( I'm all for if it ain't broke, don't mess with it!)
Chris
Carundell
Jan 9, 2007.
AD
