Mechanics
SNAPPED WATER PUMP BOLT IN TIMING CASE C
2000 Dodge Caravan
Engine Cooling problem
2000 Dodge Caravan 6 cyl Front Wheel Drive Automatic
While removing a water pump on a 2000 Dodge
Caravan 3.3 Litre V6 upper Left bolt snaped off no bolt sticking out.
Last person to install a water pump must have cross theraded the bolt realy good.
Can this bolt be extracted without open heart surgery and having to remove the timing case cover.
If I Have to remove the case how much of the eingene do I have to take appart.
Bob Wolf
February 9, 2009.
Purchase an easy out set at your local part store or tool store and use a good drill to extract it.
Thanks for using 2CarPros. Com!
Bluelightnin6
Feb 10, 2009.
AD
