Oil change light reset?
2009 DODGE CARAVAN
24,007 MILES • 6 CYL • FWD • AUTOMATIC
DOITSELF
How do you cancel the change oil mesage after you change the engine oil or will this cancel automaticly when you change the oil?
Apr 9, 2010 at 1:08 PM
CH112063
  • CAR REPAIR CONTRIBUTOR
  • 1,320 POSTS
Each has a different way to reset. Try turning the key on, hit the accelerator 3 times, wait and it shuts off. Let the servicing dealer do it. I know how you are anxious about it and any dealer will help you out if you can't find an owners manual or heck out this guide to help you reset the light.
https://www.2carpros.com/articles/oil-life-reset
Apr 9, 2010 at 4:50 PM
SLACUR
How do I reset the 'Change Oil' message on dash after I changed the oil?
Tnx ---Dave
Feb 19, 2021 at 6:10 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
Turn the ignition switch to the ON/RUN position, with engine off. Depress the gas pedal slowly to WOT 3 times in 10 seconds. Turn ignition off. Restart engine to verify reset was saved. Repeat as necessary
ALKELPIERRE
Change Oil Light came on took van in and had the oil changed, but they did not reset light. How do I reset the oil light in my van.
CH112063
  • 1,320 POSTS
each has a different procedure, try turning the key on and hitting the gas pedal 3 times then turning it off, if no good call the dealer. ok
SCGRANTURISMO
  • 4,897 POSTS
Hi, my name is Alex and I will be helping you.
I am not sure which of these apply to your year of vehicle so I included all of them. Please let us know which one it was, and thank you for using 2carpros. Alex.
