2000 Dodge Caravan Repair Question
Topics covered: Engine, Rpm, Air conditioner.
Asked on September 2, 2008
2000 Dodge Caravan Low idle numbers, Random engine dies
Hi. Within the last week my wife was having trouble with her van engine dying usually either stopped or coasting. I noticed it was idling low at around 500-600 rpm. Normally is around 900 rpm. Also, noticed the low idle happened when the air conditioner was running. It has cut out once, out of 8 times or so, when the air was off. We had the coil pack replaced. We had the local oil change place run their diagnostic and only said there was a fuel/air problem. They said the battery was fine and the alternator was ok as well. Engine sounds fine otherwise also. What other things should we look at?
thanks
