Oil pressure sensor
GDERITTER
  • 2000 DODGE CARAVAN
The oil light and chime going off constantly. The oil level is good. Before I brought it in to the shop, I thought I would change the oil pressure sensor. Where is this thing located? Do I need to drain the oil before I do it? Do you think this will solve the problem? Should I bring it in and have a professional look at it?
Thursday, February 12th, 2009 AT 5:17 PM
Here is a diagrams below that shows its location near the oil filter. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Friday, February 13th, 2009 AT 9:57 AM
A 3.3L and 3.8L engines its below AC compressor and 3.0 is near the starter
Friday, November 23rd, 2018 AT 6:45 PM (Merged)
SMMFAMILY5
  • 1998 DODGE CARAVAN
Six cylinder front wheel drive automatic 158,000 miles.
I am trying to locate where the oil pressure sensor is located. I have read the auto manual twice looking for it. I want to replace my current sensor to see if it fixes the periodic oil light that comes on after I have been driving it.
ZACKMAN
  • 4,202 POSTS
3.0L near the starter.
https://www.2carpros.com/forum/automotive_pictures/55316_98caravan30oil_1.jpg
3.3L/3.8L below the AC compressor
https://www.2carpros.com/forum/automotive_pictures/55316_98caravan33oil_1.jpg
NORTHERNGAL
  • 6 POSTS
  • 1999 DODGE CARAVAN
Engine Cooling problem
1999 Dodge Caravan All Wheel Drive Automatic 137, 00 miles
The oil light blinks and a bell rings when I am idling at an intersection. It's fine on when I am moving. Mechanic I spoke with says it's likely the oil pressure sensor. Called our town auto parts, they have one in stock, and say it's not a big job to change, but you need to know where it is. We bought the van second hand, and didn't get a manual with it. Can you tell me where the oil pressure sensor would be located? It's a Sport model, and also a US model (mileage is in miles, not kilometers), don't know if that would make a difference in where the sensor would be located. Need the van on a daily basis, so a quick response would be appreciated in a huge way! Thanks!
DOCFIXIT
  • 18,828 POSTS
Need to know engine size in Liters
NORTHERNGAL
  • 6 POSTS
It's a 3.3 L engine, but my daughter found the info on-line and my nephew installed it last night. Thank you though, for your prompt reply. Will definitely use your site again, nice to know that help is so readily available!
FOOTLOOSEAT163
  • 6 CYL
  • 123,000 MILES
Where is the oil sending unit located on my dodge caravan 3.8
CH112063
  • 1,320 POSTS
Hi, its in the front of the engine, below the a/c compressor, ok.
USER NOTE: It's under the back edge of the intake manifold.
LEGITIMATE007
  • 5,121 POSTS
Right next to the oil filter. You'll see a harness connected to it
JACKFOX
  • 1993 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 150,000 MILES
Where is it located?
JDL
  • 16,098 POSTS
You might check above the oil filter.
CHANTILLYLACE
  • 1995 DODGE CARAVAN
  • 6 CYL
  • 185,000 MILES
Where is the oil pressure switch on a 1995 dodge caravan v6 3.0, also can I use synthic oil in a 1995 car?
Don't-Oil Pressure Sending Unit (3.0L) On left side of cylinder block, next to oil filter. On the engine block behind the alternator.
LENVAL
How do you replace the oil pressure sending unit on a 2000 Dodge Grand Caravan, V6 3.3L SE?
BMRFIXIT
  • 19,053 POSTS
Unplug the wiring / plug
and it unscrew
screw the new one back in and plug it back
MCCAGG
  • 3.3L
I need to replace the oil sensor but I don't know where it is at
HMAC300
  • 48,601 POSTS
If you are talking about the oil pressure switch see pic. There is no oil sensor
BONIFACIOPS
  • 2.4L
  • FWD
  • 150,000 MILES
Do I need to drain oil to change oil pressure switch sensor?
CJ MEDEVAC
  • 11,004 POSTS
Negative
No, but you may want to drain and remove the oil filter. You will only lose a teeny-tiny amount of oil. The sensor is not on the pan where it would start draining (like the oil plug) Might lay a piece of cardboard under it to keep the garage floor clean from any drips
The medic
