Mechanics
IGNITION SWITCH
1999 Dodge Caravan
1999 Dodge Caravan 6 cyl Two Wheel Drive 142k miles
Please list the steps to replace a " punched" ignition
Terrigary
January 10, 2010.
REMOVAL & INSTALLATION
Ignition Lock Cylinder
CAUTION
The Supplemental Inflatable Restraint (SIR) system must be disarmed before working around the air bag or SIR wiring. Failure to do so may cause accidental deployment of the air bag, resulting in unnecessary SIR system repairs and/or personal injury.
Disconnect and isolate the negative battery cable from the battery.
In order to disarm the air bag system, allow the SIR system capacitor to discharge for at least 2 minutes, before performing any removal procedures.
Remove the screws that secure the parking brake release handle to the instrument panel.
Remove the screws that secure the bottom of the lower steering column cover to the instrument panel.
Disengage the retaining clip that holds the right side of the lower steering column cover to the instrument panel.
Remove the lower steering column cover from the vehicle.
Remove the mounting screws that hold the upper and lower steering column shrouds and remove the lower steering column shroud.
Install the ignition key and turn the key cylinder to the RUN position. This is important because it will not only aid in removal of the ignition lock, but will also place the socket (in the lock cylinder housing) in proper alignment for the installation of the replacement ignition lock.
Press in the lock cylinder retaining tab and remove the key cylinder (ignition lock).
To install: Install the ignition key into the replacement ignition lock key cylinder. Turn the key to the RUN position. Depress the ignition lock key cylinder retaining tab.
Align the shaft at the end of the ignition lock cylinder with the socket in the end of the ignition lock cylinder housing.
Align the ignition lock cylinder with the grooves in the lock cylinder housing. Push the ignition lock cylinder into the housing until the retaining tab sticks through the opening in the lock cylinder housing.
Turn the ignition key to the OFF position and remove the key.
Install the lower steering column shroud and install the mounting screws.
Place the lower steering column cover into correct position on the lower instrument panel and engage the clip that secures the right side of the cover to the instrument panel.
Install the lower steering column mounting screws.
Install the mounting screws that hold the parking brake release handle to the instrument panel.
Reconnect the negative battery cable.
Ignition Switch
Allow the SIR system capacitor to discharge for at least 2 minutes, before performing any removal procedures. The air bag system is now disabled.
Remove the key cylinder (ignition lock).
Using a No. 10 Torx tamper proof bit, remove the ignition switch mounting screw.
Depress the ignition switch retaining tab and carefully pry the ignition switch from the steering column.
Disconnect the electrical connectors from the ignition switch and remove the switch from the vehicle.
To install: Be sure the ignition switch is in the RUN position and the actuator shaft in the ignition lock housing is in the RUN position.
Reconnect the electrical connectors to the ignition switch.
Carefully install the ignition switch, making sure the ignition switch snaps over the retaining tabs.
Install and tighten the ignition switch mounting screw.
Install the key cylinder (ignition lock). Complete the installation by reversing the removal procedures.
Check switch operation.
Bluelightnin6
Jan 10, 2010.
AD
