1999 Dodge Caravan Alternator bracket removal
1999 DODGE CARAVAN
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
DTB1000
I received a verificationvtodqy for donation to answer a question but not sure question got sent:
"1999 Caravan 3.3L engine. Head freeze plug leaking want to R/R.
Removed alt. from bracket and four bolts, 3 in front, one in lower rear bracket. Bracket is not loose. Is there a still a connection between belt tensioner bracket and alt. bracket
Passing a paper between two brackets indicates something blocking paper between the two brackets
Alldata and Mitchell online provide no info on bracket
removal.
Feb 25, 2008 at 7:40 PM
