Here you are.
FUSE & CIRCUIT BREAKER I.D. (PASSENGER COMPARTMENT)
1 - 10 Amp (Red)
Panel Illumination.
2 - 10 Amp (Red)
Guage, Right High Beam Headlight, High Beam Indicator.
3 - 20 Amp (Yellow)
RR Wiper, Left Headlight High Beam.
4 - 15 Amp (Blue)
RH Park, Back-up Lights Switch & Relay, Speed Porportional Steering Module, Power Door Lock Switch Illumination, Daytime Running Light Module (Canada).
5 - 20 Amp (Yellow)
Power Door Lock Arm/Disarm Switches, Power Mirrors, Vanity, Dome, Map, Ignition and Trunk Lights, Sunroof, Radio, Power Antenna, Data Link Connector, Body Control Module.
6 - 15 Amp (Blue)
Heated Mirrors, Heated Rear Window Indicator.
7 - 20 Amp (Yellow)
Instrument Cluster Illumination, Park & Tail Lights.
8 - 10 Amp (Red)
Power Receptacle (Cigarette Lighter), Radio Amplifier, Horns.
9 - 15 Amp (Blue)
Power Door Lock Motors (Body Control Module).
10 - Not Used
Not Used.
11 - 10 Amp (Red)
Radio.
12 - 10 Amp (Red)
Left Headlight Low Beam.
13 - Spare Fuse
Not Used.
14 - Spare Fuse
Not Used.
15 - Spare Fuse
Not Used.
16 - Spare Fuse
Not Used.
PTC (POSITIVE TEMPERATURE COEFFICIENT) IDENTIFICATION
1 - 9 Amp
Power Distribution Center.
2 - 3 Amp
Left Front Door Lock.
3 - 4 Amp
Liftgate Lock Motor, Left Sliding Rear Door Lock Motor.
4 - 4 Amp
Right Front Door Lock, Right Sliding Rear Door Lock Motor.
5 - 4 Amp
Right Front Door Lock Motor, Left Front Door Lock Motor.
6 - 6 Amp
7 - 9 Amp
Left Power Window Switch.
8 - 9 Amp
Right Power Window Switch.
9 - 6 Amp
Front & Rear Washer Motor.
10 - 3 Amp
© 2008 Mitchell Repair Information Co., LLC.
Images (Click to enlarge)
Sep 21, 2020 at 10:43 AM
(Merged)
