I need to know where the starter is located in this vehicle. I am having a problem with it starting intermittently and I need to check to make sure that the wiring is tight.
Had a similar problem last year and had someone tighted the wires and it has worked fine since then until now.
It will start sometimes very consistently and other times not.
Nothing in my owners manual shows me where the starter is located so that I may check the connections.
Aug 6, 2008 at 5:52 PM
