2CarPros - Car Questions & Answers
1994 Dodge Caravan Repair Question
Topics covered: Coil pack, Engine, Fuel injector.
Asked on July 15, 2010
No spark
Electrical problem
1994 Dodge Caravan 6 cyl Two Wheel Drive Automatic 174000 miles
I had to replace the coil pack and now it has no sprark or fuel pressure
Avatar Asked by mgonuts5
Answer
Replied on July 15, 2010
Engine cranking, check primary voltage at the coil and fuel injectors. If no voltage, look for an rpm signal.
Check for applicable trouble codes. you should be able to check mil codes yourself. You cycle the on--off, on--off, on, then the mil starts flashing, you count the flashes to get the codes. Your looking for two digit codes.
Tiny Answered by JDL (expert)
14,457 answers provided
Make syre that nano of the spark plugs are cross-threaded and that the gap is correct
Tiny Answered by jcarroll
1 question asked
