Starter replacement
SMOOCHIE
  • 1999 DODGE CARAVAN
  • 6 CYL
  • 180,000 MILES
How do you change the starter on the van?
Friday, March 21st, 2008 AT 8:16 PM
BMRFIXIT
  • 19,053 POSTS
Disconnect battery negative cable
raise vehicle
remove wires at the rear of the starter
remove 3 bolts holding starter
remove starter
Friday, March 21st, 2008 AT 10:07 PM
ROADVULTURE9986
  • 1998 DODGE CARAVAN
  • 6 CYL
  • 221,000 MILES
How do I replace the starter on this vehicle?
Monday, January 6th, 2020 AT 11:49 AM (Merged)
JDL
  • 16,098 POSTS
Welcome to the forum, take the negative battery cable loose. The pictures below, came from autozone.
https://www.2carpros.com/forum/automotive_pictures/170934_starter_removal_1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/170934_starter_removal_2_1.jpg
https://www.2carpros.com/forum/automotive_pictures/170934_starter_removal_3_1.jpg
MICAHNETT
  • 5 POSTS
  • 1995 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 160,000 MILES
How do I replace starter in 3.0, 6 cylinder '95 caravan?
Monday, January 6th, 2020 AT 11:50 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
Here you go.
1. Disconnect battery ground cable, then raise and support vehicle.
2. Remove starter motor attaching bolts and nuts.
3. Disconnect all electrical connectors from starter motor and remove starter.
4. Reverse procedure to install.
MICAHNETT
  • 5 POSTS
I think the 3 bolts are 13mm. Electrical part 1/2in and (8mm) something small
SATURNTECH9
  • 30,870 POSTS
I don't know the bolt and nut head size's but they should all be metric size's.
MICAHNETT
  • 5 POSTS
Thank you for your help
MAVP618
  • 6 CYL
  • FWD
  • 168,000 MILES
How to replace a starter in a 1995 Dodge Caravan
SATURNTECH9
  • 30,870 POSTS
Your welcome that's what were here for.
CARADIODOC
  • 33,737 POSTS
Disconnect the battery negative cable. Disconnect the two wires from the starter. Remove the bolts that hold the starter to the transmission. Remove the starter. Reverse the procedure with the new starter.
PHILOSOPHER11
  • 1994 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 187,000 MILES
How do I replace the Starter on a 1994 Dodge Caravan?
  • 108,170 POSTS
Hi:
Disconect the battery first. Next locate the starter on the front of the engine at oil pan level. Now disconnect the wiring to the starter. Make a mental note of wire location. Now, there are two bolts holding the starter on to the trans. Remove the bolts and the starter will come off. Replace it in the reverse order.
RICKADAMS
  • 1993 DODGE CARAVAN
  • 3.3L
  • V6
  • FWD
  • 195,000 MILES
How do you change a starter in a 1993 Dodge Grand Caravan? I have read many online answers and some say I need to remove the tire to get access, while others say I need to remove the exhaust manifold, while others just say remove the three bolts with no suggestions on where they are located.
HMAC300
  • 48,601 POSTS
Disconnect negative battery terminal end then remove starter wires and 3 bolts holding it in. Here is a guide that will walk you through the steps to show you how its done on your car.
Cheers
