1993 Dodge Caravan Repair Question
Asked on December 19, 2007
1993 Dodge Caravan very little heat
Hi there,
I have a small problem with my 1993, Dodge Grand Caravan. I have have heat from the heater, but not enough to warm the cabin. When I select window defrost, there is enough heat to keep the windows free of ice, but my legs get cold.........Then if I select bi-level for the floor & window, the side windows will fog up.
I have changed my heater core, my thermostate & just this past June, I have to change the water pump ( as it gave out ).
I made an hour drive tonite in -10 degree temperature........apon my arrival, I was able to take the rad cap off with no pressure release what-so-ever. When I placed my finger in the rad, I found the coolant to be luke warm....I proceeded to do a rad pressure test, thinking I was losing pressure somewhere, but it tested OK. I should mention that both the rad & the reservior are full & while driving OR at an idle, the temperature gauge reads normal.
My question is, Is this signs of an air lock that I have yet to find ( as I have tried ), OR is it possible that my rad in front is no longer doing its job even though there is no leaks ??... Tomorrow I will go & replace the rad cap just for fun.
I hope that my description was enough info.
Thank you for your advice.........
Phil..
