1990 Cadillac Fleetwood car will not start
1990 CADILLAC FLEETWOOD
150,000 MILES • V8 • FWD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
The car will not start. I pulled the starter and had it checked out (with the solenoid attached to the side). Both the starter and solenoid are in good shape and working. I also pulled the battery, yet again in good shape. When I put the starter back into the car, it just clicks like the solenoid is burned out. The car does not have the solenoid up top, just attached to the starter itself. I turned the motor to make sure it is not binding up and the crank and pulleys turn freely. I checked the wiring with a voltmeter and all is good. Am I missing something here? Question (Follow Up): The problem was the neutral safety switch. I replaced and now the car works fine.
Oct 21, 2010 at 6:24 PM
2CP-ARCHIVES
  • 4,540 POSTS
Use a remote starter or a screwdriver on the battery terminal to the solenoid small terminal with a purple wire-did it crank over? If so look for power at the purple wire power-power there you have a bad starter. No power while key is in start position test the transmission range switch/neutral safety switch and ignition switch.
Oct 21, 2010 at 6:28 PM
CHERNANDEZ310
  • 7 POSTS
I am having pretty much same problem with my 89 fleetwood, front wheel drive,
Just clicks, starter checked out fine and has new battery, bad connection somewhere possibly but do not know where to start looking..! Wires are everywhere.!
Jun 3, 2013 at 11:08 AM
