dash lights out
1995 TOYOTA 4RUNNER
200,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
THEBLUEROBOT
My dash lights are out i must have bought it like that here are the details
Good fuse
Turn signal and engine lights show on dash just none of the instruments
Previous owner installed big stereo
Ive tried bypassing the dimmer switch but i may be doing it wrong, the fuse blows everytime i do.
Here is a picture
Nov 16, 2015 at 11:10 AM
CARADIODOC
  • CAR REPAIR CONTRIBUTOR
  • 34,309 POSTS
The dash light circuit is part of the rest of the lights that illuminate a lot more than the dash lights, and all of those interior lights feed off the tail light circuit. Here is a guide and the wiring diagrams so you can see how the system works. Check to see where you are losing power
Are your tail lights working because there is a tail light relay that controls the dash lights as well.
Check out the diagrams (Below). Please let us know what you find.
Cheers
Nov 16, 2015 at 2:17 PM
THEBLUEROBOT
I've already posted on several websites and up until now answers have been extremely vague. So far you have written the most.
Nov 16, 2015 at 2:49 PM
CARADIODOC
  • 34,309 POSTS
Now lets fix this puppy!
The glove box light also is fed from this circuit, but it is not controlled by the dimmer. If that light works, that takes care of the positive side of the circuit. The 12 volts comes from the tail lamp relay, so according to my diagram, you won't have a glove box light unless the running / tail lights are turned on.
The rheostat is an electronic module, but it still can be bypassed. We just need the right wire. You should have a green wire. That's the 12 volts that comes from the tail lamp relay. The white / black wire is the ground wire. The white / green is the ground wire for the lamps, but it goes through the dimmer module first on its way to ground. If you want to bypass the module to see if everything else works, either connect the white / black wire to the white / green wire, or just use a jumper wire to ground the white / green to the body.
If the lights turn on, the dimmer module must be replaced, but be sure that 12 volts is there on the green wire. It won't work if that's missing.
If you had found that 12 volt wire previously, what may have confused the issue is the dimmer is in the ground side of the circuit, not in the positive side like they used to do. The fact there's a 12 volt wire adds to the misery.
If the fuse blows when you ground the white / green wire, one of the bulbs, (sockets) is shorted, and logic would dictate it's related to the radio that was in there. The original radio most likely had two lamp wires. One was hooked to the tail lights to make the display dim. The second one was hooked to the dash light circuit to tell the display how much to dim. If someone reconnected those wires incorrectly, it is possible the tail lamp / dash lamp 12 volt supply got connected to the ground side of the lamps. That short may not cause the fuse to blow with the dimmer in the circuit, but it would if it was bypassed. This is a good suspect if the previous owner hacked off the radio's plug and spliced in the new wires. If an adapter harness was used, it's doubtful removing it is causing this problem.
One more tidbit of value. If the previous owner spliced wires for the radio, and sealed them with electrical tape, that can unravel into a gooey mess on a hot day. The dash is made of plastic, but if a bare wire touches the case of the radio, that is grounded, and a bare wire will be grounded if they touch.
To back up for a minute, with the dimmer still unplugged, and with the lights turned on, you should measure 12 volts on the white / green wire too. If you have that, nothing on that line can be grounded or open. At that point everything points to the dimmer module.
Nov 16, 2015 at 3:53 PM
THEBLUEROBOT
Alright thank you so much for your help thus far you have been very generous.
I tested the green-white and grounded off and was able to get 12+ volts.
So, deducing from your info I bought the $15 dollar switch... and, it still doesn't work!
So then I decided to switch out he tail light relay and everything came back to life :) thanks again for your help.
Nov 19, 2015 at 1:44 PM
CARADIODOC
  • 34,309 POSTS
Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help
Cheers
Nov 19, 2015 at 7:19 PM
2CP-ARCHIVES
  • 4,540 POSTS
I just bought a 1995 toyota 4runner for$500 but my problem is it had a dead battery in it . I bought a used charged battery put it in . When i try to start it nothing happens. I do have lights but no dash lights come on just the lights in both front doors and headlights. i tried to reset it by disconnecting the battery and use the vallet switch. thats the other thing everything i have read thus far says their should be either a toggle switch or a button,i have both?? i cant afford to take it to a shop.thats why i had to buy a $500 car in the first place.I am not opposed to removing the alarm system but I am not sure I want to try unless I know more about the system. I just need the quickest cheapest solution possible as i need transportation to get my mom to doctors.
Aug 14, 2018 at 1:44 PM (Merged)
POSSITIVE
I have lost the tail lights, dash lights & running lights on my 1990 Toyota 4runner.
I have checked all the fuses, and bulbs all okay.
My brake lights, headlights and turn signals all work normally.
Is this likely a relay problem?
I have noticed the fuse keeps blowing i keep replacing whats going on please advise
Only one fuse that's runs my running lights
On the drivers side under dash fuse panel
Over drive and check engine and all other dummy lights messages still work.
Head lights work, break lights work, interior lights work, turn signals work
KHLOW2008
  • 41,814 POSTS
The dash and taillights are in one circuit separate from the others. It has its own fuses and the running light fuse, that should most probably be the taillight fuse.
You need to test where a short has occurred. If anything had occurred prior to this, such as impact damages , you need to be checking that area for wires that could be exposed.
If not, unplug all taillight bulbs to check for shorting.
JERIDILEY
Headlight switch replacement will fix the problem.
BABKESM
I just bought a 97 Toyota Forerunner. Why won't my dash lights illuminate at start up? They only come on with the headlights.
KHLOW2008
  • 41,814 POSTS
That is how it should work.
HEATHER5999
I tried changing the fuse -- that wasn't the problem -- not sure what to try next -- the dash is completely dark at night --help!! Recently I had a new stereo put in and the connection to the back window is gone but the dash board was fine -- just one night I noticed it and after changing the fuse that was burnt it still does not light up at night.
KHLOW2008
  • 41,814 POSTS
You mentioned replacing a bad fuse. Recheck if the fuse is blown again., if yes, you have short in the circuit. Check the taillights and front clearance lights, are they working?
RUSSELLHILLS
When you turn the headlights on it blows the fuse to the dashlights and taillights.
HMAC300
  • 48,601 POSTS
check for a short in the wiring to taillights if something has been recently installed with screws check there first.
DAVE HILLIER
I have lost the tail lights, dash lights & running lights on my 1994 toyota 4runner.
I have checked all the fuses, all ok.
Thanks,
Dave
[quote:dbd1aff6a4="Dave Hillier"]I have lost the tail lights, dash lights & running lights on my 1994 toyota 4runner.
Thanks,
Dave[/quote:dbd1aff6a4]
Tail light control relay above the drivers kick panel fuse/relay block #1
Aug 14, 2018 at 1:45 PM (Merged)
To: rasmataz
Posted: Thu Aug 16, 2007 9:29 pm
Subject: Thanks!
Thanks very much for the help, got my lights working, donated $25.00 to the 2carpros.com
BRWNEYDGRL
I have a 1988 Toyota 4 runner that the brake lights and dash lights won't work on. I have checked all the fuses and they are fine except the ignition fuse has been rigged. All the other lights work and wiring seems fine as well. What is the problem and where should I go from here?
  • 110,190 POSTS
Power to both items go through the headlight switch. Check that.
EDLUVRR
I my 4runner is running fine. The engine turns over and will run just like before. The problem is that my windows, radio, dash gauges, windsheild wipers and parking sensor (that helps from putting the car from park to drive when pressing the break) will not work at all. I have checked all fuses and they look fine. When I put the key in the back window it rolls down but when I use the button to roll it down nothing happens. The auto door locks still work and the key sensor still bings and door ajar lights and dome light still works. What could be wrong?
Aug 14, 2018 at 1:46 PM (Merged)
JPENNINGTON
I to am having the same problem except for I cant start my 4 runner with a key I have to get under the truck and jump the starter off but after I get it running none of my dash lights,windows,radio, and gauges will work.
DOCFIXIT
  • 18,828 POSTS
Check 100 amp ALT fuse left side engine compartment box
