Red dust in distributor
CHIPENDALE
  • 1997 MERCURY VILLAGER
  • 3.0L
  • V6
  • FWD
  • 233,000 MILES
Rough idle/running all of a sudden, took the distributor cap off to investigate and saw red dust covering everything, I found online that red dust is indicative of a distributor bearing rust/wear. Replace distributor?
Monday, June 5th, 2017 AT 8:13 AM
HMAC300
  • 48,601 POSTS
Yes I would. It may be a bearing/bushing wear or on top of distributor you could try a new cap first see if that cures it.
Monday, June 5th, 2017 AT 8:15 AM
CHIPENDALE
The new cap does not resolve where the red dust is coming from though? I am interested in fixing the problem rather than the symptom.
Monday, June 5th, 2017 AT 9:57 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,833 POSTS
Yes the red dust is rust coming from the bearing which coming apart are wearing in the upper part of the distributor which is super common.
Cheers, Ken
Monday, June 5th, 2017 AT 10:54 AM
MICKSTILES
  • 1996 MERCURY VILLAGER
  • 180,000 MILES
How to replace distributor
Thursday, September 7th, 2017 AT 10:17 AM (Merged)
WRENCHTECH
  • 20,757 POSTS
NOTE: Ford does not provide a TDC (Top Dead Center) mark or determination procedure for this engine in this vehicle.
ALLDATA users have reported success using aftermarket tools to determine TDC on this engine.
REMOVAL
Disconnect the battery ground cable.
Remove the distributor cover.
Loosen the three distributor cap screws and set the distributor cap, distributor to spark plug wires, and ignition coil to distributor high tension wiring aside.
Disconnect the distributor ground connector from the tab on the distributor housing.
Disconnect the distributor harness electrical connector.
Remove the distributor electrical connector from the bracket.
Timing Marks On Crank Pulley (Yellow Is TDC)
Rotate the crankshaft until the No. 1 piston is at Top Dead Center (TDC) on the compression stroke.
- Check to be sure that the timing mark (yellow) on the crankshaft pulley and the timing pointer on the engine front cover are aligned.
Note the relation of the distributor rotor to the engine. Make a mark on an engine component to assist with installation.
Remove the distributor bolt.
Remove the distributor and the distributor base gasket.
INSTALLATION
If the crankshaft is rotated during distributor removal, rotate the crankshaft until the No. 1 piston is at TDC on the compression stroke.
Install the distributor base gasket and distributor. Engage the distributor drive gear into the camshaft sprocket. Ensure that the distributor rotor aligns with the mark made on the engine component during removal.
NOTE: During installation of the distributor, the distributor rotor will tend to shift when the gears mesh.
Install the distributor bolt finger-tight.
Install the distributor electrical connector onto the bracket.
Connect the distributor harness electrical connector.
Connect the distributor ground connector to the tab on the distributor housing.
Position the distributor cap, distributor to spark plug wires, and ignition coil to distributor high tension wiring onto the distributor.
Tighten the distributor cap screws.
Install the distributor cover.
Connect the battery ground cable.
Adjust the ignition timing.
Tighten the distributor bolt to 14-17 Nm (10-12 ft lb).
VERNON CHARLES
  • 1993 MERCURY VILLAGER
  • 3.0L
  • V6
  • FWD
  • 200,000 MILES
Took out distributor need to
To replace correctlyp
CJ MEDEVAC
  • 11,004 POSTS
THIS IS PROBABLY THE BEST-US WAY FOR YOU TO UNDERSTAND THE THEORY
OLE DAVID AND CHAD---DO A HECK OF A JAM UP JOB 'SPLAINING THIS. WATCH THEM WITH A MECHANICALLY MINDED PAL THIS MIGHT MAKE THINGS CLICK A WHOLE LOT FASTER
CLASS 1
http://www.youtube.com/watch?v=5a2X9mSSlQY
CLASS 2
http://www.youtube.com/watch?NR=1&v=FHX1yXVyIMg&feature=endscreen
PLEASE DO LET ME KNOW IF THIS HELPS!
THE MEDIC
FIXITMR
  • 9,990 POSTS
  • 3.0L
  • V6
  • 120,000 MILES
Any advice on the distributor problem that these Fords have where it fails mechanically. Is it just a matter of replacing the distributor or can other problems be involved?
KEN L
  • 42,833 POSTS
Yep these cars had a problem with the distributor I would start by replacing it. This should fix the problem.
Thursday, September 7th, 2017 AT 10:18 AM
