Mechanics
DIES AFTER IT WARMS UP TO TEMP.
1999 Dodge Ram • 150,000 miles
Starts and runs fine with a/c on. But after it warms up it dies like you shut off the key. Try to start it with the a/c on and it will not start, but turn a/c off and wait for a half hour or shoot it with a little ether and it will start and run fine. I have replaced the fuel pump, pressure regulator/filter idle air control valve, crank sensor, cam sensor, coolant temperature sensor, coil, plugs and wires, distributor cap and rotor. Have tested all relays and fuses but so far nothing has worked. Thank you
Cowboynrb
September 16, 2013.
Scan for codes and check fuel pressure with a gauge, sounds like the pressure is low.
Hmac300
Sep 16, 2013.
AD
