1996 Daihatsu Other
Computer problem
1996 Other Daihatsu Models 4 cyl Four Wheel Drive Automatic
You certainly cannot help me, but I must try anyway. Certainly you enjoy a good challenge? I am working on a Daihatsu Hyjet from Japan. A 3cyl engine. Year is ST210 whatever that codes out to, (1996 is best guess) No injector pulse, won't fire on ether. Was told computer is weak in these models. Cannot scan, scanner does not support these models, software is still in Japan. I found 2 hall-effect sensors 1 in timing cover 1 in valve cover runs off camshaft, am I missing a crank sensor? I changed rear cam sensor with no change. Also took front apart, timing belt is ok. Computer is little black box, took that apart, no burns, all looks to be ok. Have import book for american models, this one is not supported, do you know how to make the check engine light blink me a code? There is a OBD2 connector (but that dont work on any scanner) certainly there is " old school way"?
William treder
January 20, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
