2CarPros - Car Questions & Answers
1997 Daihatsu Applause Repair Question
Topics covered: Fuel pump, Fuse, Engine.
Asked on March 10, 2009
1997 Daihatsu Applause engine do not start - EFI car
Electrical problem
1997 Daihatsu Applause 4 cyl Two Wheel Drive Manual
the fuel run off, than i fill it ,now the fuse of the EFI
is torn twice-when i tried to start the engine.
the fuse is 15 amp, i think that meybe one electric connection in the fuel system is bad- i did not found
the fuel pump on or in the tank,i only found the float unit with the electric connection.
meybe the fuel pump damaged without fuel???
meybe the fuel pump shut with dirt-without fuel??
i cheked the out pipe of the fuel filter -with start key if it gets fuel stream -it not ,meybe because of the fuse - electric problem??
i need to know where is the fuel pump - to access it
and check it,and her electric connection.
thank you!!!
Avatar Asked by shlo
No Answer Yet
