Mechanics
WHERE IS THE PCV VAVLE?
2000 Daewoo Lanos
2000 Daewoo Lanos 4 cyl Front Wheel Drive Automatic 130000 miles
We are experiencing a 0300 diagnostic code. We have already changed the spark plugs & gasket cover. My husband is assuming that we might need to change the PCV valve. Where is it located & does this sound like a possibility for the misfire & check engine code?
Thank you!
AD
Robin5656
March 19, 2008.
It may but I doubt it.
You should check your ignition timing and compression test the cylinders.
Also have your ignition coil checked for the voltage coming off.
You may need a tune up also.
PCV valve is located on the valve covers.
Blackop555
Mar 19, 2008.
AD
