Mechanics
CUTS OUT AT IDLE DOES NOT STALL
2003 Ford Focus • 65,000 miles
Car cuts out at idle does not stall light comes on and off. Have not scanned for dtc codes. How would you check the voltage on the throttle position sensor? Or how would you tell if it was bad?And what about the mass air flow?
Randy sharp
April 26, 2013.
I wouldn't do anything until I got the codes read. Post the code numbers here and we will go from there.
Wrenchtech
Apr 26, 2013.
AD
