cruise control
ALL OTHER MAKES ALL OTHER MODELS
FLIVER
  • 9 POSTS
Cruise control intermittent. As the engine gets to normal opp. temp.the cruise light flashes, the cruise cuts in & out repeatedly then cuts off. If you turn off the main switch on left side of dash for a few min. Then the cruise works for a short time then starts all over again. Sometimes the trans tries to shift up & down as the cruise is jerking the car.
Apr 12, 2013 at 4:51 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
check grounds and have scanned to see if modle is ok
Apr 13, 2013 at 5:39 AM
FLIVER
  • 9 POSTS
hmac300.... thank you Sir, I will. I appreciat tbe help......fliver
Apr 13, 2013 at 8:20 AM
