Mechanics
COOLANT LEAK
1981 Ford F-150 • 90,008 miles
I have replaced my radiator, radiator hoses, heater core and hoses, thermostat, and poured in new coolant and it looks like the bottom of the water pump leaks only when I let it sit over night. Before I replaced the heater core coolant would come out of the firewall and leak out on the passenger side floor in the cab after I replaced the heater core the only leak was the heater box in the cab so I have it disconnected from the water pump at the moment. I don't have a clue what else to do besides replace the water pump and I need a heater since it gets cold up here in the winter.
1981Ranger
May 5, 2013.
Pressure check your coolant system or have apro do it.
Hmac300
May 5, 2013.
And how do I do that and sorry it might be a stupid question but I've ve never done it before
AD
1981Ranger
May 6, 2013.
You can either rent the tool or have apro do It betteroff with apro as you've never done that
Hmac300
May 8, 2013.
AD
