1999 Citroen Other Repair Question
Asked on June 14, 2009
1999 Other Citroen Models clutch
Transmission problem
1999 Other Citroen Models 4 cyl Front Wheel Drive Manual
i have a citroen berlingo and the clutch pedal is near the floor it went all of a sudden when driving i can still get gears only just and the clutch bites about an inch from the floor but at speed it just revs and does not drive the pedal does not spring back up aswell and i have seen a bolt loose on the pedal arm under the steerring wheel any help would be realy helpfull many thanks carl
Answer
Replied on June 17, 2009
have the pedal repaired and have a tech check the clutch operation ..
