2CarPros - Car Questions & Answers
Chrysler Town and Country Repair Question
Topics covered: Transmission, Engine, Exhaust.
Asked on April 4, 2006
Spark plugs/ oil/Transmission
I have a 1995 Town and Country with 196,225 miles. I changed the front spark plugs 2 days ago, but I can't get to the rear 3 plugs. I was told that I would have to take the exhaust off. Do I, and what is the best way to get to them? Also I am putting High Mileage oil in. Which is better: high mileage or synthetic? I changed the transmission fluid after 30,000 miles. What is the best interval and type of ATF fluid to use? Also, I heard there are many problems with this transmission? Is it true and what are the problems?
Avatar Asked by AFCENT
Answer
Replied on April 5, 2006
if you have a pair of ramps, pull it up on top and set the park brake. then slide in under from the front on your back. then you can almost set up behind the engine and get to the plugs. be safe and good luck...vandrangon
Tiny Answered by vandragon
5 questions asked
