Mechanics
FRONT BRAKE PAD REPLACEMENT ON A 96
1996 Chrysler Sebring
Does anyone know if replacing the front brake pads on a 96 Sebring is difficult? Are there any special trips or tricks that one should know about before hand?
Thanx.
jchmelik
Jchmelik
June 7, 2006.
If the brakes are rotor brake then it will be just like on any other car. Its hard but can be done yourself. Just remember to put it back together the way you took it apart. If you have a repair manual it should explain the procedure.
Killzodiak
Jun 7, 2006.
