starter location?
2006 CHRYSLER SEBRING
13,400 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
DIANA B
Starter fuses keeps blowing. I change it then it runs for a month or so then blows again. After changing fuse this time car will not start.
Jul 26, 2015 at 12:33 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
cold be a short in wiring, or maybe a starter relay bad or a starter drawing to many amps. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
Jul 26, 2015 at 4:16 PM
U149476
How do i remove the starter? Thanks
Jan 5, 2020 at 8:12 PM (Merged)
  • 54,350 POSTS
Hey U149476,
It looks like the starter is located just above the passengers side drive axle. The top bolts looks like it will be a little tough to get to but hang in there and use a universal socket if you can.
Here is a guide to let you know what you are in for and a diagram below.
Please let us know happens so it will help others.
Best, Ken
CED11
Just replaced starter thought it was the problem. Not the problem it cranks when it wants. it's a chrysler sebring 2.7L. Is it some kind of sensor?
Jan 5, 2020 at 8:13 PM (Merged)
  • 110,190 POSTS
Check battery terminals to make sure they are clean and tight and not corroded. Check starter relay. Check for power to the smaller wire on starter while helper turns key to start position and starter isn't working.
HONEYLOVE
Engine Mechanical problem
2004 Chrysler Sebring 4 cyl Automatic 90000 miles
Can you please tell me where the starter is located on the above referenced vehicle? My car won't even turn over. We thought it might be the battery, but the headlights work. Thank you so much.
BLUELIGHTNIN6
  • 16,542 POSTS
Your starter is located on left rear of engine, underneath vehicle. You can also just follow battery cable down and it will lead you straight to it.
Thanks for using 2CarPros.com !
