drivers door wont open
2008 CHRYSLER SEBRING
JIMMYMAC6860
i cannot open the drivers door with the key, all the other doors open but the drivers door wont
Jan 17, 2010 at 3:10 AM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
It sounds like the lock rod from the door tumbler has fallen off. Then best way to fix this problem is to remove both front seats so you can get the door panel off. Then look inside the door to check the lock rod.
Here is a guide to help you get the door panel off.
https://www.2carpros.com/articles/door-panel-removal
Check out the diagrams (Below)
Cheers, Ken
Jan 18, 2018 at 4:02 PM
MQ
drivers door won't open when cold. The door is keyless entry therefore not able to put any antifreeze into lock. Door will only open when temperture rises. I have tried putting wd40 onto the parts of the lock that i can see without removing door panel.
Please advise
Aug 22, 2019 at 6:34 PM (Merged)
when it warms up, remove the panel and clean out all the old lubricant and add new wd40 or some other lube product
WHITEBUFFALO
2001 Chrysler Sebring
When we attempt to open the door from the inside, it simply won't open. We need to roll down the window and reach outside and open the door using the outside handle.
Any thoughts?
ZACKMAN
  • 4,202 POSTS
Remove the door panel and make sure the door lock linkage is actually attached to inside door handle. A lot of time, the plastic retaining clip breaks off of the linkage from the handle.
