Mechanics
GEAR SHIFT SENSOR AND SPEED SENSOR
2002 Chrysler PT Cruiser
Electrical problem
2002 Chrysler PT Cruiser 4 cyl Front Wheel Drive Automatic 106000 miles
I have a promblem with my 2002 Chysler PT Cruiser. The diagnostic reads as follows:
Fault code 1: 52
Description : Po732 Gear Shift Ratio Error in 2nd.
yFault code: 2: 28
Desciption: PO706 Check shift signal
Fault Code: 3: 22
Fault Code: 4: 41
Fault Code: 5: 36
Desription: P1790 fault immediately after shift Fault Code6: 57
Description: P0720 Output Speed sensor error
Fault 7: 56
Description: Input Speed Sensor Error Please I will like to fix these faults and errors by myself. Can you explain what this means and how I should fix them all. Thanks
Kunle Sadiq
October 1, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
