2004 Chrysler Pacifica
Electrical problem
2004 Chrysler Pacifica 6 cyl All Wheel Drive Automatic 100000 miles
I started my car, everything was fine, then I felt that something burnt, I moved further, on the panel showed up a sign " battery" red, I got back home. When I turned my car down, it could not start over anymore, I checked the starter, starter was receiving plus, but didn' work.I 'd took off the starter, it didn't work, I replaced the new starter, the car didn't start over again, I gave minus to the motor, the car started, drove 5 miles and appeared " check engine" sign, I checked by OBD-II, showed me " park /neutral switch problem.
That's my question. My car now can start from any position of the transmission
parking/drive reverse.
That's my question, should I replace the switch parking/neutral or no?Or any electr. Problem. And if switch park/neutral bad -where is it located.
Thank you!
September 24, 2010.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
