2004 Chrysler Pacifica Repair Question
Topics covered: Click, Door, Door latch.
Asked on March 23, 2009
Chrysler Pacifica Click Problem
2004 Chrysler Pacifica 6 cyl Front Wheel Drive
The liftgate on my pacifica would not open but the lights would fllash and it beep like it is going to open. I have to manually opn it. the other day i used the remote to see what would happen if i tried using the remote to open it. lights flashed it beeped and it opened all the way up but i had to manually close it . since then it flashes n beeps n will not open at all even manually when the car is unlocked. if i try to open it from the outside i hear a click whe i use the handle and it will not open. i was able to open it from the inside using the emergency door latch. do i need a new motor or actuator?
