Chrysler Other Repair Question
Topics covered: Squeaking, Transfer case, U joint.
Asked on May 18, 2006
Cricket noises
When I take off from a dead start and go slow I hear alot of squeaking from below and as I go faster it sounds like crickets chirpping. I noticed it is coming from the drive shaft in the middle of the truck. I replaced the fluid in the transfer case and I only got out 10oz of fluid. i put back at least 20oz before it started weeping out of the filler hole? Is it a possible bad bearing?
Answer
Replied on June 7, 2006
It sounds like you have u joints that need replacing
