2CarPros - Car Questions & Answers
2001 Chrysler LHS Repair Question
Topics covered: Radio, Battery, Body.
Asked on September 8, 2010
2001 Chrysler LHS Stereo flash programming
Electrical problem
2001 Chrysler LHS 6 cyl Front Wheel Drive Automatic 63000 miles
I just replaced the battery and now the stereo EQ lites are flashing. The radio and in dash CD changer do not power up. ALL OF THE FUSES ARE GOOD.
The system is the Infiniti premium 11 speaker 435 watt sound system. the EQ lites flash continually not in a coded sequence. (fault code) I am a retired ASE master tech and former Chrysler field service engineer, I called dealer and was told that the radio could not be flashed. I do not beleive that is the case with this system, I beleive it is controlled by the BCM (body control module). Before blowing $100 can you verify flash programming parameters for this vehicle?
Avatar Asked by Keith W.
No Answer Yet
