1999 Chrysler LHS Repair Question
Topics covered: Control panel, Panel, Fuse.
Asked on September 21, 2010
1999 Chrysler LHS Heater control panel
Heater problem
1999 Chrysler LHS 6 cyl Front Wheel Drive Automatic 199000 miles
My control panel will not lite up all the time.When I
First start it up it works as I drive it stops ligthing up.
can this be a fuse or bulb
Answer
Replied on September 21, 2010
if its lighting up and then going out it's neither the fuse nor the bulb because it would either work or not work then. most likely it is either loose/damaged wiring to the back of the control panel or the control panel itself is starting to fail.
