Mechanics
WATER LEAK
1995 Chrysler LHS
Engine Cooling problem
1995 Chrysler LHS 6 cyl Front Wheel Drive Automatic 120000 miles
water is leaking profusely from a weephole between the transmission bell-housing and the block. How can I determine if its a blown head-gasket, a cracked head, or an internal crack in the block? Could there be another reason for this leak? Thanks
Charlquar
February 18, 2010.
Do you live in an area that is cold?
