2CarPros - Car Questions & Answers
1995 Chrysler LHS Repair Question
Topics covered: Engine, Sensor, Compression.
Asked on September 21, 2010
Engine performance
Heater problem
1995 Chrysler LHS 6 cyl Two Wheel Drive Automatic 181000 miles
Dear Technician;
Engine runs a little rough and the engine light comes on indicating "Oxygen Sensors". I have replaced the Oxygen Sensors, run cleaner through the lines, run 89 octane fuel and have put a can of "Sea Foam" in the fuel tank. All Cylinders have good compression. However -- odd cylinders, 1, 3, 5, (left bank) are producing too much carbon and the carbon is fouling the spark plugs. (I assume too much fuel on that side.) I have checked everything that I know to check and have about given up. Can you suggest anything. If someone comes up with the answer I will make a donation. I have spent lots of money to get this far.
Thank you for your time.
Sincerely,
Howard Smith
Avatar Asked by hsmith5973
No Answer Yet
