Mechanics
CHRYSLER LHS BATTERY PROBLEM
1994 Chrysler LHS
Electrical problem
1994 Chrysler LHS 6 cyl Front Wheel Drive Automatic
I have a 94 Chrysler LHS the battery keeps draining itself even if the car is shut off, and it blew one ignition fuse when I was driving it, then the car went dead after words. I ran a diagnostics test containing light bleeps off the dash board and it read a code 14 when I looked it up, it said it was a map sensor electrical circuit.
With the map sensor is it possible for it to drain the battery while the vehicle is turned off and what else could be wrong with it.
Xylem102007
June 7, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
