2CarPros - Car Questions & Answers
1986 Chrysler Le Baron Repair Question
Topics covered: Axle, Differential, Mechanic.
Asked on January 13, 2009
1986 Chrysler Le Baron fluid leaking
Drive Train Axles Bearings problem
1986 Chrysler Le Baron 4 cyl Front Wheel Drive Automatic 65000 miles
Fluid is leaking from the trans. oil seal on the drivers side. I replaced the oil seal and fluid is still leaking, a mechanic told me the pinion bearing in the differential is worn out and is causing the fluid leak. I need to know what parts need to be taken off in order to replace the bearing.
Avatar Asked by jmurray3746
Answer
Replied on March 17, 2009
The pinion is part of the trans housing on this car and requires you remove the trans to access it. I recommend getting a repair manual for this major of a repair.
Tiny Answered by Jacobandnickolas (expert)
57,318 answers provided
